Old 06-05-2014, 03:43 PM   #21
cogito ergo moo
Cowracer's Avatar
Make sure the 'bucking' you feel really aint just a loose sloppy hitch. Ford factory hitch receivers seem really sloppy. With my dear old 94 GMC, I literally had to beat the hitches into and out of the receiver. Now with my Excursion, the same hitches will rattle around. Pulling an empty box trailer would make me think that the hitch broke, it would buck around so much.
I used this...
Roadmaster Quiet Hitch for 2" Trailer Hitches Roadmaster Hitch Accessories RM-061
Not the most elegant solution, but it worked great.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 06-05-2014, 05:02 PM   #22
Canonman's Avatar
I use a Husky Centerline WDH and anti-sway system. Since my tongue weight is well within the limit for my 3/4 ton TV, I decided to be a little lazy and not hook everything up to take the TT down for some new tires (about 15 mi by freeway). I did notice what I will call the bucking sensation during my drive there and back at 65 or so mph. I do not notice anything like this with the whole set up installed. I am definitely in the WDH/anti-sway camp. Short hops are one thing but I wouldn't want a 100 mi of that ride!
FR Wildwood 22 RKS
2007 1/2 Dodge 2500, Cummins 6.7
Retirement training completed
Currently enjoying second childhood
Canonman is offline   Reply With Quote
Old 06-05-2014, 05:18 PM   #23
ironj's Avatar
Mine did that when oversprung AND undersprung in wdh bars......I say did because I put bags on and it does not ever do it now....but before one link the wrong way instigated the springy truck butt syndrome...
sent from fat fingers via a space dish thing with no regard to grammer.
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 06-08-2014, 03:06 PM   #24
mlong's Avatar
Here is a picture from this weekends trip. Not much bend in the bars.
I don't know how accurate this is but, I placed a level on the frame of the TT and it was slightly nose high. I placed the level on the frame of the TV and it was slightly nose high also. It tows well but I do have a little bucking. I do have P rated tires and stock suspension with the Chevy Z71 tow package.
2012 Chevy Silverado Crew Cab Short bed 5.3L v8
2014 Prime Time Manufacturing Avenger ATI 27BBS
mlong is offline   Reply With Quote
Old 06-08-2014, 04:13 PM   #25
2014 XLR 27HFS
Originally Posted by AquaMan View Post
Do you have a WDH? If so, that could be your problem. You may be taking too much weight off your truck. Unload the bars or remove completely, if your truck's hitch is rated for the weight. Make sure all hitch components are tight.
I agree. With that much truck you shouldn't feel it or need weight distribution till you near the 10K mark. My previous TV was an F250 SD diesel. What a mule.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 06-08-2014, 04:23 PM   #26
2014 XLR 27HFS
Originally Posted by mlong View Post
...They had me back the truck up and drop the coupler down on the ball enough to lock the coupler in place. Then crack the tongue back up to reduce the amount of force you need to apply to the bars will getting the chains hooked up. Once everything is hooked up lower the tongue all the way. Use the reverse process to unhook. Works great!
I'm pretty strong, but would never be able to lock my WD bars in if I didn't use this method. Would likely break an arm unhooking them if I didn't lift the back of the truck up first. They do make some interesting creaking noises when the weight comes back down. Over the years though, it has become a comforting sound. I know they are making a strong bond between TV and TT.
Dave & Audrey
Old 06-08-2014, 06:18 PM   #27
rburns4147's Avatar
I'm new to it. This is my first WDH but, a friend of mine has a Reese. I've seen him struggle getting tension on the bars. I've heard the sounds that it makes. It would scare the crap out of me every time for a while if I had to deal with that noise.
One tip/trick the dealer showed me (a few of the TT dealer techs were at a Blue Ox seminar shortly before we got ours). They had me back the truck up and drop the coupler down on the ball enough to lock the coupler in place. Then crack the tongue back up to reduce the amount of force you need to apply to the bars will getting the chains hooked up. Once everything is hooked up lower the tongue all the way. Use the reverse process to unhook. Works great!
When we had our travel trailer, I hooked up exactly like this. But I did buy an electric tongue jack to take the work out of it. That cranking up and down got old after a while.
Ron and Elizabeth
2014 Rockwood 8285-IKWS
2006 Ford F250 6.0 Diesel 4x4
rburns4147 is offline   Reply With Quote
Old 06-18-2014, 07:58 PM   #28
mlong's Avatar
The cranking up and down does get old. I've only been on 3 trips so far and it is already annoying. I'm going to stick with the manual set up. One less electrical component to worry about. Power jack would be nice just in case my back goes out on a trip, but my soon-to-be 11 yr old son can help out.
Old 06-19-2014, 05:36 AM   #29
AquaMan's Avatar
Wait until it's 95 and 100% humidity and you're parked on a bit of an incline to the point that you are using almost the full stroke of your jack. That power jack will look mighty nice!
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 06-19-2014, 05:39 AM   #30
mlong's Avatar
Heat and humidity do not bother me that much. I used to work in a steel fab shop. We had no heat and no A/C.
towing
