Old 05-17-2018, 07:24 PM   #1
Bunk end door sealant
I wanted to know what the best silicone/caulk is to use to reseal the outer door seams of my Rockwood Roo 21SS. A picture is attached to show exactly what I want to reseal.
jjs396 is offline   Reply With Quote
Old 05-17-2018, 07:30 PM   #2
cavie's Avatar
Do not use silicone on the exterior of your trailer. Nothing will stick to it in the future. Go to your local RV store and ask for a nonsilicone calk for vertical surfaces.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-17-2018, 07:58 PM   #3
bikendan's Avatar
cavie, this thread is in the Hybrid section and the OP is talking about a Hybrid bunk door.
Hybrids do use silicone for the bunk doors and the canvas tent ends.
Equalizer WDH
Old 05-17-2018, 08:22 PM   #4
cavie's Avatar
Learn something new every day hanging around here.
Old 05-18-2018, 05:38 PM   #5
Canadian Member
When I had the Roo I only used Geocel ProFlexRV caulk on the walls and the doors.
https://www.amazon.com/Geocel-28100V.../dp/B001FC98X2
I redid the caulk on the door frames that's falling apart in the OP's picture.
I masked it off with painter's tape and applied the ProFlexRV caulk in a bead about 1/4" wide. I had to redo that caulk the year after the bunk doors were replace due to delamination of the original bunk doors.
The only silicone product I ever used was a silicone spray lubricant for the batwing antenna.
2019 Rockwood Signature 8290BS
Old 05-18-2018, 06:16 PM   #6
bikendan's Avatar
My 2007 Roo had silicone along the bunk door frame and along where the canvas attached to the wall.
Equalizer WDH
Old 05-18-2018, 06:49 PM   #7
Canadian Member
IIRC, our 2009 Roo had some kind of caulk - probably silicone based - around where the canvas met the door frame. I never personally used any silicone based caulk on it though.
Old 05-23-2018, 02:17 PM   #8
Sham183
mopwr4me2003's Avatar
Geocel. Works great but can be messy like any other silicone stuff.
mopwr4me2003 is offline   Reply With Quote
Old 05-28-2018, 08:57 PM   #9
I jave a similar issue, will Flex Seal work?
Sue
2006 Rockwood Roo 23SS
2014 Ford Expedition
High School Spanish teacher
smalt is offline   Reply With Quote
Old 05-28-2018, 10:13 PM   #10
Canadian Member
I don’t know but I’d stick with Geocel ProFlexRV. That’s the application it was designed for and it will last for quite a few years. I’m not big on all that “as seen on TV” type stuff.
bunk, door, seal
