Old 05-13-2015, 02:20 PM   #11
wicked1's Avatar
Also good because you learned something and everyone on here can benefit from your troubleshooting and solution, never know others may have that issue.
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 05-13-2015, 02:32 PM   #12
gbpacker's Avatar
Bunk light problem
Before replacing the outlet I would suggest trying dielectric grease before replacing the outlet.
gbpacker is offline   Reply With Quote
Old 05-13-2015, 03:29 PM   #13
Briorick's Avatar
Originally Posted by DK-in-SC View Post
It's a very good thing you went through this process. Having a non-functioning CO2 detector is not good. Good troubleshooting.
DK-in-SC. Thanks, and so true you are. We were just thinking how dumbfounded we were not to hear the chirping, like when we did hear in our pop up. Maybe we just get immune to hearing the sounds and take them for granted at times. Unknowingly, of course.
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 05-13-2015, 03:35 PM   #14
Briorick's Avatar
2015 Roo 23IKSS
Very true! Just as I have learned. That what is so wonderful about this forum. We learn something everyday. Without our firsthand experiences and mishaps , we would not be able to share and compare. Makes some of us beginners look and feel very confident gaining the knowledge of the seasoned campers. Love this forum.
Rick & Brian
Old 05-13-2015, 04:24 PM   #15
Briorick's Avatar
Thanks for the suggestion gbpacker. I wasn't quite sure what Dielectric Grease was, so therefore I googled it. I can see why this would be handy to have in the camper toolbox. Thanks again. Much appreciated.
Rick & Brian
Old 05-14-2015, 06:52 PM   #16
Also good for greasing your 7-pin connector on the TV. Keeps both ends (jack and plug)from corroding.
2011 Traverse LT, 3.6L, FWD
Old 05-14-2015, 08:51 PM   #17
Briorick's Avatar
OK, need more info. I am assuming you are saying to grease the inside of the TV connector, prongs and all? YES? Or just the inner plastic casing?
Rick & Brian
Old 05-14-2015, 08:54 PM   #18
Left Coast
Just the prongs...trying to keep moisture out.
Old 05-14-2015, 09:04 PM   #19
Briorick's Avatar
Got it! Thanks
Rick & Brian
Old 05-15-2015, 04:03 PM   #20
deartruc's Avatar
The co detector does have a life expectancy, like the one you should have in your house. I believe its 3-5 years. If you're hearing consistent chirping and your battery is charged or on AC, you may have a bad co detector (and the reason they pulled the fuse).
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
fan, light
