05-11-2015, 10:20 PM
Bunk End Light / Fan Port question.
Evening all.
We have a 2000 Shamrock 19' ( loving it immensely ) and was wondering if anyone has ever experienced any problems with their bunk end fan / light ports. The back port works fine, as we have tested both fans and they are working, but the front port doesn't seem to have any power going to it.
Is it possible that these do go bad?
I have taken it apart and checked the wiring, which appears to be intact. I am deciding on getting a replacement, and if need be wire it elsewhere to another existing overhead light, but figured I would throw this question out at you for some comments if anyone has had a similar problem. Thanks in advance.
Rick & Brian
2023 Flagstaff 206STSE
2019 Flagstaff HW29SC ( sold )
2017 Salem Cruise Lite 232RBXL ( sold )
2014 Ford 150 XLT 5.0 2wd
05-12-2015, 06:06 AM
Did you test the wires with a volt meter? If you don't have 12 volts at the wires your problem is someplace else.
Retired Paramedic
2020 FSX 280RT
2005 Silverado 1500 Ext cab 5.3 H.O.
2011 HD Road King
Nights camped since 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
05-12-2015, 09:16 AM
Thanks yetavon. Not as of yet. Just put her away after the weekend trip and had reminded myself of this tonight, therefore just asking in general at the moment. Thought maybe others might have had this issue as well. Troubleshooting on the honey do list this weekend.
Rick & Brian
05-12-2015, 09:38 AM
Also check the fan/light unit on the other socket gives you a quick indication what might be wrong. I never use mine but GF's daughter does and I always setup hers because she would just pull the wire out by the fan, if that kept going wouldn't be too long before I Had a short
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
05-12-2015, 01:12 PM
Sometimes the metal prongs on these get weak and lose good electrical contact with the inserted plug, so with the plastic cover off the female socket try to plug in the male end to see if contact points are weak. If you don't see a small spark ( try this in the evening) then the electrical connection to the 12V source is broken, possibly by a fuse being out. Having a cheap electrical tester (Harbor Freight or your local hardware store) in your camper is invaluable sometimes.
2014 Shamrock 183
05-12-2015, 01:43 PM
bunk light
I had same issue I replaced the plug and it worked fine they sell replacement plugs rather cleaply
05-12-2015, 02:49 PM
Thanks for the helpful tips. I did purchase a digital multimeter, just have to learn how to use it. Never really had a need for one before. So now's a good time to learn. Wish me luck! LOL. Thank goodness for YouTube videos.
Rick & Brian
05-12-2015, 03:42 PM
Well, I have an update. I did go out and remove the fan / light port and bring it in the house and test it on my RV battery. Lo and behold....the Fan and Light work as they should. Getting closer. So now have to figure out where the problem lies with the wiring. Am going to try reconnecting ( maybe a bad connection ) and see what happens next. Where there is a Will, there is a Way! LOL
Rick & Brian
05-12-2015, 04:19 PM
MYSTERY SOLVED!
Okay, what apparently happened was this. We had traded our 1940LTD Pop Up in last November for this Unit. Thought we had checked it over with a fine toothed comb, but, alas, and after just now re-checking the converter and fuses, I found a fuse 1/2 way seated. Hmmm, so I reseated the fuse the proper way and lo and behold I heard a "chirp". ( fingers crossed )
Took my meter and re-checked the wiring and got results. Put the port back together and plugged the fan / light in and it worked like a charm. Problem solved!
Apparently the salesman didn't want to hear the chirping of the Oxygen Sensor, so he disarmed it ( left the fuse 1/2 in the slot ) and when we inspected the Convertor initially, we didn't see it out-of-place.
Geesh, something so simple, but so complexed, by lack of inspection analness. LOL.
Bright side, I now have a Multimeter! YAY!
Rick & Brian
05-12-2015, 07:28 PM
It's a very good thing you went through this process. Having a non-functioning CO2 detector is not good. Good troubleshooting.
I live with fear every day, and sometimes she lets me go fishing.
2019 Surveyor 251RKS
2008 Ford Expedition EL
05-13-2015, 02:20 PM
Also good because you learned something and everyone on here can benefit from your troubleshooting and solution, never know others may have that issue.
2015 Roo 23IKSS
05-13-2015, 02:32 PM
Bunk light problem
Before replacing the outlet I would suggest trying dielectric grease before replacing the outlet.
05-13-2015, 03:29 PM
DK-in-SC. Thanks, and so true you are. We were just thinking how dumbfounded we were not to hear the chirping, like when we did hear in our pop up. Maybe we just get immune to hearing the sounds and take them for granted at times. Unknowingly, of course.
Rick & Brian
05-13-2015, 03:35 PM
2015 Roo 23IKSS
Very true! Just as I have learned. That what is so wonderful about this forum. We learn something everyday. Without our firsthand experiences and mishaps , we would not be able to share and compare. Makes some of us beginners look and feel very confident gaining the knowledge of the seasoned campers. Love this forum.
Rick & Brian
05-13-2015, 04:24 PM
Thanks for the suggestion gbpacker. I wasn't quite sure what Dielectric Grease was, so therefore I googled it. I can see why this would be handy to have in the camper toolbox. Thanks again. Much appreciated.
Rick & Brian
05-14-2015, 06:52 PM
Also good for greasing your 7-pin connector on the TV. Keeps both ends (jack and plug)from corroding.
2011 Traverse LT, 3.6L, FWD
05-14-2015, 08:51 PM
OK, need more info. I am assuming you are saying to grease the inside of the TV connector, prongs and all? YES? Or just the inner plastic casing?
Rick & Brian
05-14-2015, 08:54 PM
Left Coast
Just the prongs...trying to keep moisture out.
05-14-2015, 09:04 PM
Got it! Thanks
Rick & Brian
05-15-2015, 04:03 PM
The co detector does have a life expectancy, like the one you should have in your house. I believe its 3-5 years. If you're hearing consistent chirping and your battery is charged or on AC, you may have a bad co detector (and the reason they pulled the fuse).
2017 GMC Yukon
2018 Roo 23 ikss
