10-07-2015, 10:03 AM
Bunk end rain guards/deflector
Hey all! 1st time poster....
just bought a 2015 Shamrock 233s and one of the bunk ends let some water on the top. i know i saw some rain deflectors that we could install on the top of the bunk end to deflect the water. my luck on the search is not working at all. any help appreciated!
Thanks,
Joe
10-07-2015, 10:11 AM
Look six posts down.
Les & Heidi Kramer
2021 Jayco Melbourne 24L
Olmsted Township, OH
10-07-2015, 10:21 AM
Already did. It's like a weather tech looking plastic rain guard
10-07-2015, 10:30 AM
I slit a garden hose and put it over the top the full length.
Les & Heidi Kramer
10-07-2015, 11:31 AM
I'll try that hose trick. But I found the cover I was talking about. It's called a drip cap on rvpartsnation. Com. I was trying to get it at 86 inches long... But no cigar!
10-07-2015, 12:10 PM
Water leak at bunk ends
Had the same problem with 2014, model 19. After three attempts dealer installed a flat rubber gasket on the bunk end doors opposite the factory seals. That solved the problem. No rain leakage or bugs can get past the double seal. Since you are still under warranty, suggest same fix to your dealer.
10-07-2015, 12:31 PM
1" dia thin wall PVC pipe did the trick for me. Cut away about 1/4 of the diameter on a table saw, very easy, but very messy. I have traveled with these held in place with small bungee cords. Good luck!
2014 Rockwood Roo 233s
2014 Runaway Navigator
2013 GMC Yukon XL
10-07-2015, 12:47 PM
I sometimes find a cup of rain water pooled on the outside vinyl of the bunks when opening up... so far it has not been a problem as I always zip up the windows and it never has leaked into the inside of the bunk.
2014 Shamrock 183
10-07-2015, 01:29 PM
Forest River LISTEN to all the forum posts about Bunk End Leaks
I have posted about this and so many others have as well on current models as well as older ones.
I think it is time FR looked at this as a PROBLEM and put something in place to divert the water just like they did on the sides of the trailer.
Too many have this problem. This is a design issue that needs to be corrected by the manufacturer.
10-07-2015, 01:46 PM
I have a 2016 Roo 183 that I purchased in late spring of this year. We've camped with it six weekends with the final scheduled trip this coming weekend.
I have not seen any signs of water leakage. Does the water leak into the bunk ends when they are folded up? Have you checked the weather stripping along the top edge of the bunk?
I'll keep an eye out for this problem with mine, but so far so good. I'm not sure if FR changed the seals between 2015 and 2016.
Eric & Abby
2016 Rockwood Roo 183
2014 Ford Explorer Sport
10-08-2015, 05:21 AM
I have 2016 183 and all 3 beds leaked on mine.
10-08-2015, 05:45 AM
We have the 2013 183 and have never had a leak. Either 2014 or 2015 models came with a new style bunk latch that have garnered a lot of complaints of being flimsy and not compressing the seals adequately.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
10-08-2015, 07:11 AM
Inadequate Rain Gutter
My '09 Roo came with a tiny toy rain gutter. Just big enough to run off the dew that runs off the Roo every morning, but totally inadequate to deal with rain. I went to Home Depot and got some J flashing that sticks out about 2". I haven't had any trouble since I replaced the old gutter with flashing.
