Old 03-17-2016, 09:46 PM   #1
Bunk End Seals need to be glued
We just took delivery of our 2016 233S. I noticed that the bunk end seals had come loose in two locations. This is mostly where the seals intersect. Just a small section that appear to need to be re-glued.
What would you recommend I do to glue the seals back down. Any special type of glue, tape, or rubber cement to use?
I see Amazon has this weatherstrip adhesive ...
Amazon.com: 3M 08008 Black Super Weatherstrip Adhesive Tube - 5 oz.: Automotive
I would rather do this myself - correctly, than take it back to the dealer that is 80 miles away.
Thanks for the input!
2016 Rockwood Roo 233S
2013 Ford F150 SuperCrew 3.5 EcoBoost
rootree is offline   Reply With Quote
Old 03-18-2016, 01:28 AM   #2
Nothing to add yet, but watching as we will be picking ours up on Monday.
taz_co is offline   Reply With Quote
Old 03-18-2016, 06:26 AM   #3
Mainframe's Avatar
Coming from the auto repair industry the 3m weather strip adhesive worked well, a couple of things to watch while working with it,
1- clean BOTH surfaces to be glued with alcohol
2- it dries really fast!
3- It is slimy and gets everywhere and because it dries fast don't let that intimidate you, just make a plan, follow the directions and try to work quickly, once it takes, it usually holds well.
good luck! you can do it!
I am gonna check my seals tonight and see if they are loose.
2016 Shamrock 23WS
Mainframe is offline   Reply With Quote
bunk
