02-10-2016, 01:56 AM
Bunk ends
Hello could someone tell me why the roo 23ss brochure has the back bunk as a queen but mine is smaller
02-10-2016, 02:51 AM
Bluemax, since the 23SS came out, they have always had RV queen beds front and back.
Our 2007 23SS has two RV queen mattresses.
Why do you think yours isn't?
02-10-2016, 05:23 AM
Pretty sure all FR hybrids have the same bed size front, rear, and side if they have 3. We have a 23ikss and both are the same.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
02-10-2016, 06:48 AM
Our 23ss has the same front and rear.
02-10-2016, 07:58 AM
One of mine in my dk seems smaller because the doors are different size but as others said they should all be the same.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
02-10-2016, 12:47 PM
Bunk ends
Ok I will try this again. Being new to this forum, I put comment in the wrong place. I just purchased a roo 23ss, 2010. I have found a few issues that I could your advice, some we have a solution.
Bunks do not measure the same, back one is smaller, real bummer since this is one of the major reasons we purchased a roo
Bunks were not closed correctly so we had the leaks also the dealer must had the bunks open for show Huntsville whether for some time, so dirt and mildew too over. I was going to clean but found the gasket to be cheap to replace. New gaskets have a better compression. We are a blended family of three generations, being in the silicone valley we are all engineers. I will post some fixes for the leaks and mods we have on the way.
02-10-2016, 12:52 PM
Welcome to the forums!
When you say the bunks aren't the same size - are you talking about the door & canvas (which aren't the same size) or the actual beds (which are the same size? Both bunks use the same mattress. The front door and canvas are larger to account for the angle of the front of the trailer, but the sleeping area should be the same for both ends.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
02-10-2016, 01:02 PM
Actually I am talking about the mattress, my wife measured it and I did as with the same measurement
Back mattresses smaller
02-10-2016, 01:08 PM
Some hybrids do have same size bunks front and rear but most have a king or queen up front and then a queen or full in the back. King is rare I believe
02-10-2016, 01:12 PM
Canadian Member
IIRC, the front bunk is a queen and the rear is a double. Both beds should be hinged at the same height off the floor but, as KMP44 said, the front door can be larger due to the slope of the front wall.
02-10-2016, 01:19 PM
Canadian Member
Regarding your leaks, where are they coming from? On our previous 2010 Roo 23SS, I found that the screws securing the bed door frame were not put in at right angles to the frame, nor were they countersunk, so the screw heads stuck out and prevented a really good seal. I replaced the white seal around the bunk doors and the black pads on the latches and it helped.
02-10-2016, 02:46 PM
Thanks I saw the same thing with the screws, but also notice the hing itself can leak. FR but a drain but if the trailer is tilt up the water just goes inside. I have a fix for this, but I will also store the trailer level. My fifth wheel had a non-crowned roof so it was always stored with a tilt.
02-10-2016, 03:34 PM
Ops I also forgot to say that the brochure says both beds are 60x 80. Not so for the back bunk
02-10-2016, 04:36 PM
Canadian Member
If you have a Dremel type tool you could try to grind the protruding part of the screw head down a bit for a better seal as long as it doesn't affect being able to remove the screw. I found that trying to re-seat the screw was impossible.
02-10-2016, 05:46 PM
You say you bought a 2010, so it's used. I'm wondering if someone put a larger mattress in your front bunk, or a smaller one in the rear, for some reason.
Brochure says bunk is 60 x 80, but my actual mattress was 60 x 72. If it had been 60 x 80, the ends of the mattress would have been flush with the sides of the bunk door and would have interfered with the cable supports.
2011 Traverse LT, 3.6L, FWD
02-10-2016, 08:00 PM
I thought the same thing.
I've never measured the mattresses or doors but our 23SS mattresses are exactly the same size. The DW likes to stack them to sleep on.
02-11-2016, 02:47 AM
my 2016 has both the same size because all we have are queen size sheets, in house ,camper and our hunting cabin
02-11-2016, 09:03 PM
Yep all of you correct, I should have check what my wife had done. The back bunk looked bigger than the one in the kiwi. The big of buying a roo was the bigger beds.
02-12-2016, 04:21 AM
Not sure what you're saying.
Are the Roo's mattresses RV queens or not?
