Bunk ends
This picture shows the wire attached to the bunk fold out end. On mine, I just noticed that two of the screws are partially out and the corner of the bracket is actually slightly bent. Has anyone experienced an issue with these bunk end support screws for the cables popping out? What I am going to now do is drill through a new hole for each corner and uses a screw with a locking nut as in the centre one. There's a big washer on the outside, hopefully I can screw through this, if not, Im thinking a small metal plate? Any other solutions?
Mike & Sharron LeBlanc
2014 ford f150 fx4 ecoboost
2014 Shasta Breeze/Flyte 255RS
