Old 06-15-2012, 12:00 AM   #1
Bunk ends corners
Hi Friends,
After dealing and solving the antenna leak, just wondering why my bunk ends were a little wet after the rain. I finally detected that there is a space at the corner of the bunks ends where the water enter.
What is the best solution for this problem?
(*) Is it normal that the rear bunk end seems to fold better than the front one...It perfectly fit. The front one, close a little more out than the rear.
Bye!
Pato
patov6 is offline   Reply With Quote
Old 06-15-2012, 02:20 AM   #2
bikendan's Avatar
something isn't right about the first pic, of the front bunk.
where the door bottom meets the hinge, it looks bent.
the white trim should be right up against the door frame.
there's way too much space in between.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-15-2012, 08:05 AM   #3
I checked it again and is not bent (maybe pic effect), but you are right, is kind a lack of white trim. Maybe Ill complete the trim with a piece of rubber or something similar.
Old 10-08-2012, 10:14 PM   #4
Thanks! Now Im disassembling the front end to check and repair if something is wrong.
Old 10-11-2012, 08:46 PM   #5
Finally, the front end was rotten. Now, Im replacing the wood, sealing and repositioning the hinge. Now is closing better!
ID:	20579   Click image for larger version
ID:	20580   Click image for larger version
ID:	20581   Click image for larger version
Old 10-11-2012, 09:13 PM   #6
Triguy's Avatar
Nice work
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-12-2012, 12:51 AM   #7
bikendan's Avatar
Originally Posted by Triguy View Post
Nice work
x2!
expandable, hybrid, shamrock
