Old 10-03-2013, 08:34 AM   #1
Bunk Fan....This is a good one
Ok I am lost on this one. We have the 3 bunk fans in our unit. The rear 2 bunks that the kids occupy work fine. The front bunk, ours of course, doesn't.
When we plug the fan in, it is in reverse. Meaning the air blows out the back (top) of the unit...up towards the canvas. We have tried 6 difference fans and they work properly on the back bunks (blowing down) but they all blow up on the front bunk.
Taking a video for the service department while we are going to be out this weekend but wondering if anyone had any ideas....
2013 F-150 XTR Ecoboost 4x4, 3.73 w/Equalizer
2014 Roo 233s
Nights camped 2014: 28
Nights camped 2013: 17
Shado is offline   Reply With Quote
Old 10-03-2013, 08:40 AM   #2
jtstromsburg's Avatar
if no fans turns the right way in the front bunks, yet they work fine in the rear bunks, I'd say something is mis-wired for polarity? If it's just a particular fan, i'd say the fan is mis-wired.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 10-03-2013, 08:48 AM   #3
Correct - all 6 blow up on the front bunk.
All 6 work correctly blowing down on the rear bunks.
2014 Roo 233s
Old 10-03-2013, 09:02 AM   #4
if these are 12v fans, which I'm thinking they are, i'd turn off 12 v power and pull the recepticles out and reverse the wires. Realizing it's new and your dealer should take care of it, but if it's simple, it might be fun to do it yourself.
good luck
Joel
Joel and Teresa
2016 Sabre 34TBOK
Old 10-03-2013, 10:45 AM   #5
Triguy's Avatar
Agree about the wiring. I could see how a mistake like this could be done incorrectly by a factory tech working fast. It should be easy to fix; either you or the dealer just need to rewire the front receptacle.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-03-2013, 11:50 AM   #6
Agree, just switch the leads on the front fan.
Old 10-24-2013, 09:16 PM   #7
I had the same issue with my 23B Roo. Take the front jack apart and switch the black and white wires. Someone at the factory is getting confused because usually the black wire goes to the negative terminal, but for some reason they wire these trailers with the Black wire going to what is considered the positive, center portion of the jack. Mine work fine now.
Snowman56
2014 Rockwood Ultra lite 2304S
2012 Silverado 1500 crew cab
Snowman56 is offline   Reply With Quote
Old 10-31-2013, 02:52 AM   #8
Engineer of Crazy Train
ChooChooMan74's Avatar
Sounds like someone wanted to get home on Friday and wired that bunk backwards. Easy fix.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 10-31-2013, 06:02 PM   #9
Hey, how do you know that it isn't the OTHER 2 fans that are backwards? I don't think the fans say anything on them on which way they're supposed to blow. When it's hot out, I'd want the fan to blow cool outside air into the center of the trailer. When it's cold outside, I'd want it blow warmer air from the center of the trailer into the bunk ends.
2011 Traverse LT, 3.6L, FWD
Old 10-31-2013, 06:17 PM   #10
Originally Posted by rockfordroo View Post
... When it's hot out, I'd want the fan to blow cool outside air into the center of the trailer...
If it's hot outside, how can you blow cool air in from the outside???
fan
