Old 10-01-2015, 12:42 PM   #1
Bunk Leaks - Anyone use EZE RV Gutters?
I know a lot of us with hybrids have issues with the top edge of the bunk ends leaking while closed. I was wondering if anyone ever tried the EZE RV Gutters? They are very inexpensive and look like they might do the trick.
http://www.campingworld.com/shopping...ge-black/16961
hjznewcomb is offline   Reply With Quote
Old 10-02-2015, 10:01 AM   #2
wicked1's Avatar
Seems simple but I know a lot of ppl I have seen use 2" pic pipe they cut and put on the Bunk End gutters, there are some people in here with photos just have to search the threads
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 10-02-2015, 11:19 AM   #3
Jimandchris's Avatar
Difficult to see in the photo, but doesn't look like it's wide enough to cover the exposed seal on the newer units...
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 10-06-2015, 04:19 PM   #4
Crusader 816's Avatar
Use the pic mod. Have had it for 2 yr and no leaks. Very inexpensive to make and took about an hour to do.
Crusader 816 is online now   Reply With Quote
Old 10-06-2015, 07:45 PM   #5
pxt
I'm having aluminum gutters custom made. Don't want to keep putting something there every time I'm not using trailer.
pxt is offline   Reply With Quote
Old 10-06-2015, 08:27 PM   #6
Make sure the gutters cover the opening on the doors because that's where these things leak. I hope they work but I just don't see how they will cover the complete opening and you not having to move them. That's why the pvc works because it goes over the top of the door to let the water run over the top and down the outer part of the door. Yes it can be a pain some times but it's been dry for a whole year now. Not a drop. Good luck and send photos,would like to see them. Those stick on gutters will not work.
bunk, leak
