Old 07-13-2013, 10:56 PM   #21
CDNWhiskey's Avatar
If your lights aren't LED insist they swap them out. If you have to do it you'll pay a lot for the lights. My unit is a 2013 23SS (built in Sept 2012) and didn't have LED. If yours comes with you're ahead of the game.
CDNWhiskey is offline   Reply With Quote
Old 07-13-2013, 11:20 PM   #22
TeresaInCAL
TeresaInCAL's Avatar
Originally Posted by budven View Post
I am considering buying a new Rockwood Roo 23ss and need help from some of you seasoned veterans in choosing the options. I live in southeastern PA and will be towing with a 2010 Ford Explorer 4x4 4.8L engine with the tow package which I believe is rated for 7115lbs.
Here are my questions...
1. Do I really want/ need a power awning vs. a manual awning?2. What aboutaluminum wheels vs. standard wheels?3. Do I really need heated holding tanks?
4. Do I really need a power tongue jack?
5. Should I buy the brake controller and install it myself?
6. Should I buy the Equal-i-zer 4 pt. 1000/10000 myself?
Any other advise is welcome as I am in the research stage of buying.
Thanks for any help.
1-power awning= no
2-?
3-?
4-YES
5-have the dealer/mechanic install it
6-?
My 2 cents
Teresa
2013 f150 Ecoboost 4x4
2009 Gray Wolf, 22BH
TeresaInCAL is offline   Reply With Quote
Old 07-14-2013, 04:54 AM   #23
Rrickim63's Avatar
Originally Posted by TeresaInCAL View Post
1-power awning= no
2-?
3-?
4-YES
6-?
My 2 cents
I wish you luck on towing with explorer. We had similar one and it struggled with a pop up although rated much higher. The transmission is the weak link...
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 07-15-2013, 07:10 AM   #24
Dave Lyon's Avatar
  • Yes to power.
  • I choose aluminum, due to rust issue and appearance.
  • only if camping in cold weather. If declined this option.
  • Absolutley, the best $135 you'll spend.
  • you can. I negotiated mine, including intallation as part of the purchase
  • See #5 (I opted for an E2)
  • A second Fantasic fan in the front might be a handy option. Yes, to slide toppers. I opted for the raised panels on the fridge, they look great. I supplied the battery, and bought a group 31, deep cycle.
Have fun and good luck with your buy.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
