Old 10-06-2011, 09:17 PM   #1
Bypass valve location
I am newby. Have an rood 177, where is the hot h2o water heater bypass and how can I access it?
tomcamper is offline   Reply With Quote
Old 10-07-2011, 12:00 AM   #2
TURBS's Avatar
Normally directly behind hw heater.
Access may be gained by opening cupboard doors on the inside of camper or removing a panel inadequate a cupboard.
Old 10-07-2011, 10:05 AM   #3
Triguy's Avatar
I'm not familiar with a Roo 177, but the smaller trailers generally have access only from the inside so f1100 nailed it.
Locate the water heater panel on the outside, which is probably near the front of your trailer and then locate the cupboard on the inside that holds the tank. There might or might not be a false panel that you would have to remove (just a couple of screws).
There are probably three valves. Bypass is the one that connects the in and out lines.
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
