Old 05-18-2015, 11:21 AM   #1
Bypass valves
Hey guys. I know typically you will have 3 valves but in the roo 21ss I just got there is a valve on the cold water, one on the line between the hot and cold but no valve on the hot line. Is this a new way they are set up or was it never setup to bypass from the get go. Only thing I can think is that the hot has a check valve on it.
wraenking is offline   Reply With Quote
bypass, valve
