Old 09-03-2014, 12:33 PM   #1
Old Ram Guy
Avenger61's Avatar
Bypassing the Water Filter
I want to completely remove or bypass the water filter on my 23IKSS and just use a portable water filter that hangs from the city water supply. I have no desire to remove the panel inside the rear cargo hatch to change out my water filter or take a chance that the filter will leak (and I wont know until I have a small flood). I could have sworn that I seen someone explain how they did this in a post, but I can't seem to find it now. I actually considered just moving the water filter location to just inside the access panel under the rear bunk, but I'm not sure that changes the problem a lot. I also want to know if I have to use compression fittings on the new hoses to do this or can I just use regular hose clamps?
Marty, Jenice and DD
Avenger61 is offline   Reply With Quote
Old 09-03-2014, 12:43 PM   #2
That was me after mine exploded and started gushing water into our 233S. We replaced it with a whole house canister in the same location but you can easily move it to the outside.
Cut out the lines that are in there on either side of the current filter. I personally used shark bite connectors with a piece of pvc. Very simple to do.
a friend of our loves the filter that he bought one as well and connected it to the exterior of his and setup the filter with gardena quick connects.
Any questions let me know.
2013 F-150 XTR Ecoboost 4x4, 3.73 w/Equalizer
2014 Roo 233s
Nights camped 2014: 28
Nights camped 2013: 17
Shado is offline   Reply With Quote
Old 09-03-2014, 12:44 PM   #3
Here is the link to my post regarding it
Water Filter Replacement Options
2014 Roo 233s
Old 09-03-2014, 01:01 PM   #4
vinmaker's Avatar
I should have done that on my old pop up. Will definitely consider it on the new unit.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-03-2014, 01:41 PM   #5
Old Ram Guy
Avenger61's Avatar
Thanks Shado, that should work! I think I'll just cut out the cannister, as you suggested, and use an outside filter. I'm not familiar with Shark Bite fittings but they look simple enough. Will they work on reinforced 1/2" hose or do I need to use PVC or PEX pipe?
Old 09-03-2014, 01:46 PM   #6
Not sure if reinforced hose would work. I would stick with a piece of PEX. HD sold it here in Canada for something like $5 for 10 ft.
The connector would be something like this:
SharkBite 1/2 in. Brass Push-Fit Check Valve-U2008-0000LFA at The Home Depot
They are designed to be a push together fitting instead of getting the crimper required for PEX pipe. Have used these connectors in the camper and in the house with no issues
2014 Roo 233s
Old 09-03-2014, 01:50 PM   #7
Old Ram Guy
Avenger61's Avatar
That's great and that's what I'll do!! Thank you so much for the feedback.
Old 09-03-2014, 02:04 PM   #8
Old Ram Guy
Avenger61's Avatar
One more question. Do I really need the check valve fitting or would a straight coupling work just as well? I'm not sure I would have a back flow issue at the filter.
bypass, water, water filter
