Old 06-22-2019, 10:32 PM   #41
Wprather's Avatar
Originally Posted by bikendan View Post
It came from the factory with one. Unless a previous owner removed it.
I found it. I was being a bit of a dufus. I was looking at the picture and didn't realize it is connected directly to the water pump! I was looking other places on the line. Duh, it's right there on the inlet side of the pump, which makes total sense. Turning brain back on now!
2018 Rockwood Roo 233S
2003 Chevy 3/4T Suburban
TST Tire Monitor Tow/Trailer
Wprather is offline   Reply With Quote
Old 06-23-2019, 11:48 AM   #42
Bacchus's Avatar
I have a 2017 21ss and the filter started leaking this week. I was looking at the filter you installed which looks like a good alternative to the OEM filter. In looking at the filter and the photo you have it looks like there is no way to attach it yet in your second photo it looks like it is attacked. I have a question, how is the filter top attacked?
2017 Flagstaff Shamrock 21ss pulled by a 2007 Ford F150 XLT 4X4
Bacchus is offline   Reply With Quote
Old 06-23-2019, 12:07 PM   #43
If you are referring to my post I attached it with the screws that were used on the original. The GE filter has a bracket similar to the the FR filter.
Take the FR one out first and bring the elbows that connected it to the pex line with you to the to the hardware store. You will need a couple of fittings in addition to the filter.
Many connect with shark bite connectors but they are pricey IMO. For $20 I bought the correct crimper on Amazon which came with a bag of assorted fittings. Now I have the crimper and a bag of fittings for anything else I might want to do.
Bob
HappyTrav is offline   Reply With Quote
Old 06-23-2019, 01:36 PM   #44
Bacchus's Avatar
Thanks for the reply. I removed the filter from the wall and after looking at it I was wondering if you knew how to get the crimp rings off without damaging the pex, that is provided that they can be removed. I have worked with all kinds of plumbing but never had the opportunity to work with pex until now.
Old 06-23-2019, 04:32 PM   #45
The ring fitting is pretty stout. Stainless steel I think. I use a pair dykes (diagonal cutters) to roll back the locking tab. Once you do that they can be unwound enough to slide right off after you get the angle fitting off.
I have read where others have used a dreamed to cut them off.
Bob
Old 06-23-2019, 05:51 PM   #46
People will tell you not to, but:
I unscrewed on fitting, letting it rotate in the Pex. Then you can rotate the filter to unscrew the other fitting. Put in a 1/2" coupler the same way.
If you have 90 degree fittings, this won't work.
People say the fitting will leak if you do this, but mine's been good for 4 years now.
Name:	half inch DURA coupling.jpg
ID:	208043   Click image for larger version
Name:	Filter replacement coupling.jpg
2011 Traverse LT, 3.6L, FWD
Old 06-23-2019, 06:52 PM   #47
Bacchus's Avatar
Thanks to both of you, now I have a good idea how to go about this. I have a straight fitting on one side and an angled on the other. It looks like I can take off the straight fitting and then rotate the housing to get the other end free. Then either install the GE filter or use a ½ inch coupler and be done with it.
233, 233s, bypass, roo, water, water filter
