Old 10-11-2013, 06:36 PM   #1
urocav2001's Avatar
Cable
I'm at a Koa that has cable, I attached the cable line to the line and attached it to the camper, now I don't get any reception on the tv? Any suggestions?
urocav2001 is offline   Reply With Quote
Old 10-11-2013, 06:56 PM   #2
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Three things I can think of. 1. Did you turn your power boost off? 2. Did you set your TV up in the menu selection for cable reception instead of air or antenna? 3. Check and recheck your connections and make sure the center conductor of your coax is being fed into the female end of the adjacent connector and hasn't been crushed over. Good Luck...Do your neighbors have reception?
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 10-11-2013, 07:30 PM   #3
Love My Sunseeker
DXSMac's Avatar
Or sometimes you have a bad cable, buy another cable. I had to do that once.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 10-12-2013, 10:43 AM   #4
urocav2001's Avatar
Ok figured it out its basic cable do I needed to keep it on air on TV and I got the basic thirteen channels with booster off, thanks
Old 10-12-2013, 02:03 PM   #5
caper's Avatar
The TV should be changed from air to cable.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 10-12-2013, 03:14 PM   #6
urocav2001's Avatar
If I put it on cable it doesn't find any channels? What could be wrong , I know it's cable reception
Old 10-12-2013, 04:01 PM   #7
Fulltime family RVer
Your TV needs to be on cable as well, the booster had to be OFF (that's only for over the air channels).
Old 10-12-2013, 05:13 PM   #8
caper's Avatar
We have two hook up outside. One for cable and then other is for SAT. If you are using the wrong hookup "cable" will not work.
Terry and Janet
2007 Ford F150
Old 10-13-2013, 07:26 AM   #9
On our Roo we have three different places inside to hook the cable to. The antenna was easy to figure out so I had to try the other two until I was able to find cable stations on the TV.
electrician549 is offline   Reply With Quote
Old 10-13-2013, 08:19 AM   #10
If you had done it right, the Cable signal would have come out the same port as the antenna once you turned the antenna booster off.
expandable, hybrid, shamrock
