Old 07-20-2015, 07:25 PM   #21
Crockett's Avatar
the following is pure conjecture on my part. i noticed the alpha shipped with the skylight is high solids, low VOC. maybe the equivalent of the non-sag dicor but with different VOCs possibly. Ive seen the plastic on the skylight discolor and be prone to cracking right where the dicor stops and the skylight begins on the sealing edge. at least the non-sag might be a better choice here with less VOCs....at least on the edge next to the acrylic.
Crockett is offline   Reply With Quote
Old 07-20-2015, 07:56 PM   #22
lgray's Avatar
I wonder just how much of the deterioration of the skylight is purely related to the elements and/or mounting stress points. My roof is on a fifth wheel kept at a seasonal site in Florida, full sun and salt air, 24/7. The majority of our neighbors, who have developed leaks, get them from the skylights. Most if not all of the skylights are black, attract sun and get very hot, every day. To me it makes sense that it is just a matter of time before they get brittle and start to leak. Shortly after caulking, I spray painted mine with an entire can of Krylon, 4 coats. It is now bouncing the sunís rays and is much coolerÖ
I am also curious to know if the skylights are made of the same materials. When cleaning this one I was surprised that when I pushed down on it, my thumb easily depressed the surface, very similar to a large childrenís ball. Could have sworn that the material on my past RV skylights was much harder.
lgray is offline   Reply With Quote
Old 07-20-2015, 08:24 PM   #23
Crockett's Avatar
your pretty much right about the sun. i just snug them down when i swap them. too much deformation when tightening will crack it over time. 303 at regular intervals might be better than the VOCs in paint but ive never painted to know. if i can find a skylight with the crazing at the edge where the caulk meets ill post..
Old 07-27-2015, 06:06 PM   #24
Aqualight's Avatar
X3 on the Eternabond tape. It fixed my leaking problems around the antennae, bathroom skylight, and the front part of the roof (above the front bunk) where it starts to make the curve. I had major leaking problems above the front bunk and this fixed it. After 2 years it is still holding up in the Texas sun. Very easy to install and is not messy. I've used Eternabond brand and another cheaper version found on Amazon and both work and held up the same.
As a wise man once said, "Wherever you go, there you are."
2018 Rockwood Roo 23IKSS
2010 Ford F-150 Super Crew Lariat
Previously owned a 2011 Rockwood Roo 19
Aqualight is offline   Reply With Quote
Old 10-01-2015, 08:09 PM   #25
Life Without Whine's Avatar
So the title to this thread included other seams so would love to ask if anyone caulks around the windows as well as the roof. We have Microlite 21FBRS & DH finished roof today & was wondering .....
Terri & Joe, Roxie & BrewDog Boont
Camping on average a long weekend every month since starting in May of 2013 .... Florida is a great state to have this bad habit
Life Without Whine is offline   Reply With Quote
Old 10-01-2015, 11:22 PM   #26
Crockett's Avatar
i do windows all the time. some have a foam sealant that dries out leaving large gaps, especially on the non-smooth side coaches. my fav is lexel at ace in clear. the 35 year silicone/ acrylic is common for colors.
Old 10-02-2015, 07:55 AM   #27
PhoneDude 8289's Avatar
What are the frameless windows sealed to the unit with, looks like a gasket of some sort.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
caulk, roo, roof
