Old 06-02-2016, 01:58 PM   #1
Caution with the Grill Mount Rail
I have a Roo 17 and purchased a grill to use with the supplied rail and propane hose. The first time I fired up the grill it worked fine but while I was waiting for it to cool down it fell off the rail. Well I looked at the bracket that hooks onto the rail and it didn't seem to have much of a hook to hold the rail so I closed the channel a bit and solved that issue. So second time worked fine but the rail appeared to be canted a bit. Now I just used it again and you guessed it the rail is coming loose. I unscrewed the rail and found that Forest River had screwed the rail to the gel coat only and nothing went into anything of any strength. I've now screwed the rail through to a plywood backer on the inside and it should stay. Sooo! - for safety don't use the rail until you run the screws into something other than the gel coat. 2 1/4 screws will give you about 3/4 ths of an inch on the inside and use can use the grill rail without fear. I shudder to think what might have happened if a large pot of baked beans or corn on the cob had dropped of onto one of my family.
Happy camping.
DocRob is offline   Reply With Quote
Old 06-02-2016, 04:28 PM   #2
Why did you have to purchase a grill? RVQ grill should have come with your Roo. You should have a table that slides onto the rail, also.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 06-02-2016, 06:45 PM   #3
bikendan's Avatar
Yep, you not supposed to get the rail and propane hose, without getting the grill.
It's a package option.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-02-2016, 07:20 PM   #4
Grill rail issue
I didn't purchase the grill but suspect that someone may have put on the rail before they looked at the invoice. At any rate the issue with the rail stands and the grill I ended up with is an Olympian 5500 that works great
I had a number of other issues that I fixed rather than getting old waiting for service at the local dealer, but this one is dangerous so thought others should know.
Old 06-03-2016, 11:27 AM   #5
My rail came loose on my old Shamrock 183 while I was in the middle of barbequing. Caught it just in time.
This was mounted at the FR factory and no problems on prior occasions of use. Repaired with wider screws after shooting epoxy into the holes and allowing to partial set. Never used that set-up too often after that. Current RV has the bumper mount - much safer.
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017
CNYCamper is offline   Reply With Quote
Old 06-03-2016, 11:35 AM   #6
I have the rail and gas port on our 17 23WS and did not buy the grill option. Roo rep told me they are all built with the rail and gas port.
Mr Havercamp is offline   Reply With Quote
Old 06-03-2016, 11:45 AM   #7
I've used the grill and shelf (usually for an electric griddle) more than dozen times with no issues. I will definitely keep a close eye on it though. Thanks for the notice.
Are you sure that the grill was on the bracket properly? My wife attached it once, and I noticed that she missed the bottom lip of the bracket (barely holding on to the top lip). The grill was holding, but wasn't fully attached.
ebcobra93 is offline   Reply With Quote
Old 06-03-2016, 11:59 AM   #8
Grill
Yes the grill was mounted properly it was the rail that wasn't! So you have a grill of about 15 lbs, a table with fixins on it, grill tools, meat and the like. You need more than an 1/8th inch of gel coat to hold it. That's even without someone loosing there balance and reaching for the table for support (didn't happen yet but it could) In this world were everyone is a lawyer or has a phone I find it hard to believe that FR would take that kind of risk.
Old 06-03-2016, 12:08 PM   #9
Sorry, missed the part about the screws pulling loose...
Eric & Abby
2016 Rockwood Roo 183
2014 Ford Explorer Sport
Old 06-03-2016, 01:17 PM   #10
mike.t's Avatar
This is how I mounted mine (yes I know it is not a Roo)
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
mount
