Old 08-23-2015, 05:05 PM   #21
rbq
I'm a little confused about some of the responses here. Don't the Roo's have auto changeover regulators so that you leave both valves open & they will automatically change from one to the other if one of them runs out?
2001 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 08-23-2015, 05:12 PM   #22
Ford Idaho's Avatar
My unit has an auto changer, problem is how to tell when it changes.
I run one tank till its empty then switch it by hand.
I pull the empty out and get it filled ASAP.
Old 08-23-2015, 05:19 PM   #23
Jimandchris's Avatar
X2, Our Roo has the auto changeover, added the window to see when it switched so I could change out the empty tank. Haven't run out of propane yet.....
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 08-23-2015, 05:44 PM   #24
DK-in-SC's Avatar
Yes, you are absolutely correct. The problem with that is if you always keep both tanks open you may not realize that one has gone empty. By only having one open, you will use it until it is empty and then you will turn it off and open the second tank. Doing it that way doesn't take advantage of the auto switching regulator, but it does keep you in touch with your propane levels.
I live with fear every day, and sometimes she lets me go fishing.
2015 Shamrock 23IKSS
2008 Ford Expedition EL
DH-DW-D3K-DMTTSAP
DK-in-SC is offline   Reply With Quote
Old 08-23-2015, 07:50 PM   #25
You have two options.
1. Run manually. You'll know when to switch when your furnace/fridge stops working.
2. Run the auto switch over regulator. Now you have to check it periodically or you'll run out both tanks.
So your choice is to not check and perhaps run out in the middle of a cold night, or run on the auto regulator and check it "regularly."
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 08-26-2015, 09:12 PM   #26
Now that I understand the whole Selector/Auto Switch option that is the way we will go. It ends up that I did not have a propane shortage issue. Apparently when working on my furnace the tech left the selector switch pointing in the opposite direction of the tank I was using (and I had not set it up for auto nor did I have both tank opened up.) It was pointing to a tank I had closed. I read the instructions and what do you know, it is actually quite easy when you read the instructions! Doh! And we have plenty of gas - probably enough to get us through next year as well.
drhroo is offline   Reply With Quote
Old 08-26-2015, 09:20 PM   #27
Who Dares, Wins
doc73's Avatar
Glad it worked out. Something did not seem right with all that gas usage!
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 08-26-2015, 10:01 PM   #28
When all else fails - read the instructions.
Old 08-27-2015, 02:14 AM   #29
bikendan's Avatar
x2.
now you know it wasn't the two of you wasting the propane!
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 08-27-2015, 02:37 AM   #30
Just a member
kandl's Avatar
Leave both tanks open and let the auto changeover valve do its thing. Daily check the indicator on the valve with an inspection mirror through the top hatch - no need to cut another window in the tank enclosure. Some inspection mirrors even come with LED lights.
http://www.amazon.com/s?ie=UTF8&page...20with%20light
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
cover, propane
