Old 04-13-2013, 04:06 PM   #21
J R
Screw with a Roo
Here's a pic of my slide lock bars underneath my slide. The slide on the 21ss is huge and shoring it up makes a world of difference. It is a concern if the trailer should shift one way or another, but if you are on steady ground, I see no problem.
Jim & Char
2011 Coachmen Encounter 36KS
Towing a 2005 Jeep Grand Cherokee
J R is offline   Reply With Quote
Old 04-13-2013, 04:21 PM   #22
Triguy's Avatar
Now I see how you did it, Jim. I can well imagine that is helpful to reduce trailer movement in that big slide.
What you are doing used to be common when slides first came out in trailers, but not recommended nowadays because of the concern OldCoot brought up. And, its not just shifting or sinking ground, but what happens if a tire loses air?
I'm just bringing this to your attention as I see it as a risk.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-13-2013, 07:10 PM   #23
bikendan's Avatar
Doing this will void the the trailer's or slide mechanism's warranty if you have any problems.
My owner's manual had paperwork to that effect.
Old 04-22-2013, 08:08 AM   #24
thebrakeman's Avatar
Roto-chock, X-chocks, etc: If they lock the tires together, preventing either from rotating, then the performance (as far as preventing trailer wiggle) will be identical.
We use 2 X-chocks, and it did make a significant different. But trailer wiggle can never be eliminated by fixing the centerpoint of the trailer (the tires), especially on a longer trailer like our 27' bunkhouse. The tires are flexible. Getting out of our front hybrid bunk will be felt back in the rear bunkhouse, and vice-versa when one of the girls jumps down from a bunk (no matter how many times I tell not to...don't get me started).
Tighten the X-chocks (Rotos, etc) as instructed, and snug up the front/rear stabilizers as much as you dare, and enjoy camping.
thebrakeman is offline   Reply With Quote
Old 04-22-2013, 09:26 AM   #25
OL Creeker's Avatar
Welcome to the club! I too bought a set of mechanical Chocks, without realizing the tight clearance between tires. I took 'em back, bought X-Chocks. The camper is much more stable with them.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 04-22-2013, 09:41 AM   #26
NiteNoise's Avatar
Question about Roto choks or BAL: do you use them on one side or both sidess of the TT?
__________________________
2013 Rockwoood 2910TS
https://www.forestriverforums.com/for...55-albums.html
NiteNoise is offline   Reply With Quote
Old 04-22-2013, 10:03 AM   #27
OL Creeker's Avatar
I have two sets. One for each side
Duramax/Allison
Old 04-22-2013, 11:33 AM   #28
Always Learning
Both. RotoChocks recommends it that way (of course they do- they're selling them! :-)). But, I still use on both sides.
Same with regular ole chocks.
