04-12-2013, 01:01 PM
Chock question
When we went to Florida I had bought the BAL X Chock and the BAL standard tire chock. My thinking was the standard tire lock would go between the tires to chock the camper and the X chock would take out some of the wiggle. I didn't realize how close the tires were to each other and was surprised when I got down there and couldn't get the standard tire lock to slide in.
What is everybody using? Just the X chock (or the homemade version) to chock the camper? I saw the OneStep chocks but I think they wouldn't fit either. OR do you have the single tire chock from BAL?
'18 Ford F250 Lariat Super Crew
'22 Rockwood 2608BS
Previous '17 Grand Design Imagine 2800BH, '13 Rockwood Roo 21SS
04-12-2013, 01:03 PM
Always Learning
RotoChocks. They have different sizes depending on how close your tires are.
Expensive, but worth it!
04-12-2013, 01:20 PM
Camper Less Camping
X2...I had the same problem when we bought another camper...RotoChocks are the ticket & a great product!
2013 Sabre 32RCTS-6 (sold)
04-12-2013, 01:25 PM
Roto Choks are the way to go, or a homemade version of depending hiow much red neck you want to be.
Rotochok
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
04-12-2013, 03:31 PM
I have the BAL X-chocks, and they fit my 233s. I still have a lot of wiggle and I was just going to post to see if anyone has a solution.
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
04-12-2013, 04:16 PM
You will find no better chock at holding a unit firm than the aforementioned Roto-Chock! They are a bit pricey, but you will be very happy with the results!
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
04-12-2013, 04:17 PM
I also read the X-chocks would do the trick...
Kristina
2021 F150 XLT
Previously:
04-12-2013, 04:18 PM
Always Learning
Probably worth it's own thread- but the only solution to wiggle is extra stabilizers. Start with a product like JT's StrongArms (or UltraFab Eliminators or the SteadyFast system or your own home grown DIY solution). Then, if that's not enough- look at extra stabilizers near the axles. I'm trying the Valterra Stabilizer Stands. I have very low expectations that they'll work, but I'm hoping their ease of setup makes them worth it. I should find out next weekend.
04-12-2013, 04:35 PM
The X-Chocks require more room between the tires than do the Roto-Chocks. If there is sufficient room, the X-Chocks may fit, but I still don't think that they hold as well, plus they require a wrench (a ratchet works better) to install and remove.
Fire Instructor
04-12-2013, 04:46 PM
Any type chock that keeps the tires from moving will work. X-Chocks, Roto-Chocks, Bal Chocks or homemade. You have to look at all of them and make your own choice. Bottom line, they all work, no one better than the other if they hold the tires from moving. Just personal preference. Axle stab jacks do eliminate the bounce from the tires and suspension and the JT type stabilizers, etc also reduce/eliminate the front to back & side to side motion.
04-12-2013, 05:11 PM
I use the BAL Xchocks with my 233S. Does a great job as a chock and a fair job as a stab, but I don't know if any other brand would be any better removing trailer motion.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
04-12-2013, 05:41 PM
I made my own. Had the items needed at home so no cost. They do stop most of the movement in the TT. I also have extra jacks in front of the axles. Have eliminated 99% of movement.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
04-12-2013, 07:55 PM
I can feel my 5 year old rolling over in bed. I tighten the chocks after everything has had a chance to settle, including the stabilizing jacks.
Kristina
2021 F150 XLT
Previously:
04-12-2013, 08:14 PM
Denver, CO
X5. Roto's are awesome
2017 Fuse 23T
04-12-2013, 08:28 PM
But Roto chocks require a handle to tighten and then putting a pin in place which requires two hands. I know they can be also be padlocked, but if someone wants them, a knife will cut the strap. I could drill the hex on my Bal Chocks and prevent them from being removed, but see no advantage to locking them. If someone wants either kind, all they have to do is puncture a tire. Rather have them steal the chock than ruin a tire. Just my take.
04-12-2013, 08:29 PM
Roto Chox. X6!
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
04-12-2013, 08:33 PM
Roto Chocks x7
Kevin & Janine
2019 F350 Lariat DRW
2020 Jayco Pinnacle 36KPTS
04-13-2013, 12:11 PM
Screw with a Roo
I use my slide lock bars to shore up outside underneath my slide and x-chocks between my wheels. This takes out the bounce and sturdies up everything.
Jim & Char
2011 Coachmen Encounter 36KS
Towing a 2005 Jeep Grand Cherokee
04-13-2013, 12:16 PM
I think you might be asking for a problem by shoring up the slide. If the trailer sinks a small amount and the slide doesn't, you are putting a load on the slide that it is not designed to handle and it could be damaged.
Would you have a picture of that setup?
Scott
2012 Shamrock 233S
