Old 04-12-2013, 01:01 PM   #1
grege's Avatar
Chock question
When we went to Florida I had bought the BAL X Chock and the BAL standard tire chock. My thinking was the standard tire lock would go between the tires to chock the camper and the X chock would take out some of the wiggle. I didn't realize how close the tires were to each other and was surprised when I got down there and couldn't get the standard tire lock to slide in.
What is everybody using? Just the X chock (or the homemade version) to chock the camper? I saw the OneStep chocks but I think they wouldn't fit either. OR do you have the single tire chock from BAL?
'12 Ford F150 Lariat Super Crew
'17 Grand Design Imagine 2800BH (Previous '13 Roo 21SS)
2016 Nights camped: 7
2015 Nights camped: 21
2014 Nights camped: 18
2013 Nights camped: 26
grege is offline   Reply With Quote
Old 04-12-2013, 01:03 PM   #2
Fulltime family RVer
RotoChocks. They have different sizes depending on how close your tires are.
Expensive, but worth it!
Old 04-12-2013, 01:20 PM   #3
Camper Less Camping
Cajun Po-Boy's Avatar
X2...I had the same problem when we bought another camper...RotoChocks are the ticket & a great product!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 04-12-2013, 01:25 PM   #4
SYE
SYE's Avatar
Roto Choks are the way to go, or a homemade version of depending hiow much red neck you want to be.
Rotochok
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 04-12-2013, 03:31 PM   #5
hockeytownmom's Avatar
I have the BAL X-chocks, and they fit my 233s. I still have a lot of wiggle and I was just going to post to see if anyone has a solution.
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 04-12-2013, 04:16 PM   #6
Fire Instructor's Avatar
You will find no better chock at holding a unit firm than the aforementioned Roto-Chock! They are a bit pricey, but you will be very happy with the results!
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 04-12-2013, 04:17 PM   #7
I also read the X-chocks would do the trick...
Kristina & Family
Old 04-12-2013, 04:18 PM   #8
Probably worth it's own thread- but the only solution to wiggle is extra stabilizers. Start with a product like JT's StrongArms (or UltraFab Eliminators or the SteadyFast system or your own home grown DIY solution). Then, if that's not enough- look at extra stabilizers near the axles. I'm trying the Valterra Stabilizer Stands. I have very low expectations that they'll work, but I'm hoping their ease of setup makes them worth it. I should find out next weekend.
Old 04-12-2013, 04:35 PM   #9
The X-Chocks require more room between the tires than do the Roto-Chocks. If there is sufficient room, the X-Chocks may fit, but I still don't think that they hold as well, plus they require a wrench (a ratchet works better) to install and remove.
Fire Instructor
Old 04-12-2013, 04:46 PM   #10
Any type chock that keeps the tires from moving will work. X-Chocks, Roto-Chocks, Bal Chocks or homemade. You have to look at all of them and make your own choice. Bottom line, they all work, no one better than the other if they hold the tires from moving. Just personal preference. Axle stab jacks do eliminate the bounce from the tires and suspension and the JT type stabilizers, etc also reduce/eliminate the front to back & side to side motion.
