Old 03-26-2016, 09:20 AM   #11
Old Member
Yours is a fairly new trailer, however, I've experienced a cracked city water connection. Easy to replace.
Cool Canuck is offline   Reply With Quote
Old 03-26-2016, 09:54 AM   #12
fedrocker's Avatar
I am using it week after next for Spring Break, and out of town next week, so I have to pay someone to do it. Hate it.
2011 Rockwood Roo 233s
2007 Tundra Crewmax, 5.7
fedrocker is offline   Reply With Quote
Old 03-26-2016, 10:05 AM   #13
Ford Idaho's Avatar
Would you be able to find someone who could do it better than you in your needed time frame?
Old 03-26-2016, 03:38 PM   #14
Shouldnt exceed 45-50 lbs.
It's about 55-75 lbs ...
TheGreatWaz00 is offline   Reply With Quote
Old 03-26-2016, 04:04 PM   #15
caper's Avatar
If you take the outside fitting off (remove 3 screws) there is a check valve attached to the fitting. It just screws on easy to fix should not take any longer then 1/2 to 1 hour if not less. I had to replace mine because the valve was not working and when I was using the water pump water was leaving the TT through the city water connection.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-26-2016, 05:39 PM   #16
fedrocker's Avatar
Ready for this? The hose washer had fallen out or was pulled out somehow ... Problem solved.
Old 03-26-2016, 05:41 PM   #17
Mainframe's Avatar
Well that is great news! Best fix ever! Now time to go camping!
2016 Shamrock 23WS
Mainframe is offline   Reply With Quote
Old 03-26-2016, 05:47 PM   #18
Ford Idaho's Avatar
I had that happen last year, went out for our last trip of the year and had water blowing every where.
Pulled it apart the little red washer had walked.
Good thing I had a couple of spares.......
Old 03-27-2016, 08:43 AM   #19
fedrocker's Avatar
Ford - where was that info when you first posted ?! 😜
Old 03-27-2016, 08:48 AM   #20
Ford Idaho's Avatar
Forgive me, information related to?
leak, water, water connection
