Old 03-25-2016, 05:34 PM   #1
fedrocker's Avatar
City Water Connection Leak
So I am de-winterizing my Roo, which I blew out with air pressure and filled with antifreeze before temperatures dropped, and there's water spraying at the city water/hose connection. And water is spraying inside the trailer at the connection.
I tried tightening the coupler from the inside but it's still leaking on both sides of the trailer. Anybody know what this might be?
I disassembled the pump bypass in case that caused low pressure on one end, but it didn't fix the problem.
Mike.
2011 Rockwood Roo 233s
2007 Tundra Crewmax, 5.7
fedrocker is offline   Reply With Quote
Old 03-25-2016, 07:43 PM   #2
fedrocker's Avatar
Would the yard hose directly in the city water connection bust the valve? I forgot to connect to my RV hose at first.
Old 03-25-2016, 07:49 PM   #3
Ford Idaho's Avatar
Do you know what kind of pressure your house water is running at?
Old 03-25-2016, 07:52 PM   #4
fedrocker's Avatar
No, but I'm now thinking it's the reason ... What do you think?
Old 03-25-2016, 07:59 PM   #5
fedrocker's Avatar
It's about 55-75 lbs ...
Old 03-26-2016, 08:13 AM   #6
fedrocker's Avatar
Anyone?
Old 03-26-2016, 08:25 AM   #7
Jimandchris's Avatar
That's a bit high, but I don't think that would be enough to make it leak that much. If it's leaking on outside and inside, are you sure it didn't freeze and crack? I have a separate inlet for the antifreeze but it doesn't put any antifreeze in the plumbing from the city inlet down to the valve. When I winterize I let the pump pressurize the system with the antifreeze, then go out and push in the check valve at the city water inlet to make sure antifreeze gets in that section. (Standing off too one side!) Not sure if all tt's are plumbed that way. Good luck!
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 03-26-2016, 08:31 AM   #8
Mainframe's Avatar
You froze something I bet, I would get it apart an diagnose it, get it fixed, season is coming!
2016 Shamrock 23WS
Mainframe is offline   Reply With Quote
Old 03-26-2016, 08:45 AM   #9
Residual water can cause issues as I found out last week. I ran water lines to my garage for my pressure washer and ran them with a slope so they could gravity drain into the basement drain fitting. Wouldn't you know it, I now have a leak in the pex line in my garage even though the line was drained and blown dry with air compressor too!
I gotta remove a ton of slotwall in my garage to repair it ;-(
Good luck, your camper repair should be easy.
Skyliner is offline   Reply With Quote
Old 03-26-2016, 09:07 AM   #10
fedrocker's Avatar
I bet that's it - the only part of my plumbing that didn't get any antifreeze. Have to see if there's a check valve. If not, I need to definitely figure something else out.
leak, water, water connection
