Old 07-25-2015, 11:57 PM   #1
grege's Avatar
City water issue
Hey all,
We arrived in Florida today to camp for the week. We have city water so I connected to it and pressurized the camper. I went over to my brother in laws camper and when I came back water was spewing out of my water tank fill. I turned off the city water for now.
It's dark so can't see much outside. Figured I'd just use the pump and holding tank water. I was wondering if anyone knew what valve I must have in the wrong position for my city water to fill my holding tank. Just would make it easier in the morning if someone else has had this issue before me and figured it out.
Greg
'12 Ford F150 Lariat Super Crew
'17 Grand Design Imagine 2800BH (Previous '13 Roo 21SS)
2016 Nights camped: 7
2015 Nights camped: 21
2014 Nights camped: 18
2013 Nights camped: 26
grege is offline   Reply With Quote
Old 07-26-2015, 03:32 AM   #2
bikendan's Avatar
Bad check valve
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-26-2015, 03:54 AM   #3
Bad check valve or unseated check valve. High pressure water systems can unseat the rubber check valve located in the head of the water pump.
Trevor43 is offline   Reply With Quote
Old 07-26-2015, 04:25 AM   #4
Check valve issue in Pump! Are you now and have you been using a (Pressure Reducer Valve) on your (Incoming Water Supply? Youroo!!
Old 07-26-2015, 08:11 AM   #5
grege's Avatar
Where is the check valve? I have a pressure reducer but didn't install it last night since I was in a hurry. Ugh.
Any chance I can fix it or will I need to replace it?
Old 07-26-2015, 08:14 AM   #6
".......Bad check valve or unseated check valve. High pressure water systems can unseat the rubber check valve located in the head of the water pump......"
Old 07-26-2015, 08:42 AM   #7
I know this is not exactly like yours but it shows the pump head and the three check valves........one or more has come unseated by the high pressure........just make sure no debris has gotten in there. They are black rubber gaskets that act like flaps. Item #2 will hold the three check valves.
http://www.forestriverforums.com/for...1&d=1400382255
Old 07-26-2015, 08:52 AM   #8
Flybob's Avatar
Usually following these simple steps will cure the problem
Disconnect city water
Turn on water in camper to relieve pressure.
Turn on water pump in RV and tun water for w few seconds
Turn off faucet
Turn off water pump
Reconnect city water.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-26-2015, 09:48 AM   #9
Yep.....this would reseat them. Good idea
Turn off faucet
Turn off water pump
Old 07-26-2015, 09:54 AM   #10
Witch Doctor's Avatar
Turn off faucet
Turn off water pump
X'2 what Flybob wrote. If still will not close then you are going to either get a rebuild kit easy to do or replace the pump...
Coachmen M/H
Concord
2018 / 300 DSC
water
