09-30-2016, 07:49 PM
Co2 detector no lights on
Hello I have a shamrock 233s 2013 and just notice that my co2 detector has no green light or red light on
Anyone know what it mean
09-30-2016, 08:33 PM
Are you having any 12v issues, in the trailer?
09-30-2016, 10:00 PM
Yes my light are not working without electricity but my batterie indicate full charge on the panel
10-01-2016, 08:13 PM
Is your battery shut off switch turned on? If it is like the switch on our 23IKSS it has a silver colored knob that has to be pulled to turn on the battery and pushed to shut power off from the battery. Ours is located low on the wall down near the floor, easy to bump it with something and accidentally shut it off.
10-01-2016, 08:31 PM
RCCS, not sure that 2013 models had a factory disconnect switch.
10-01-2016, 10:14 PM
My 2012 Roo 19 did.
2011 Traverse LT, 3.6L, FWD
10-02-2016, 08:41 AM
Ok guys you were right my switch under the fridge was the problem for my lights...so one problem solved
But the CO2 detector there is still no lights on...Anyone know what to do thanks all
10-02-2016, 08:44 AM
I'd check for an in-line fuse.
10-02-2016, 08:51 AM
Under the fridge I have my panel with brakers and fuses
Here is the list of my equipment
15 amp porch
15 amp kitchen
15 amp bath
15 amp refer furn
15 amp living room
7.5 amp A/C
15 amp tv boost
15 amp radio
I've got 2 other 40 amp
So I don't know if it could be a fuse
10-02-2016, 09:03 AM
The CO detector usually comes right off the battery cut off switch, I believe, so I think it has an in-line fuse, not through the panel. (Similar to a power front jack or a slide-out, although these may or may not go through the battery cut off switch.)
Try a search for "CO detector" and you'll learn more.
10-02-2016, 09:41 AM
Check to see if it operates by pressing the test button on the CO2 detector itself. If it does you will know you have 12v to it and maybe a defective LED (highly unlikely). If you do have a defective LED, I would replace it as you don't want to be guessing if it's working.
10-02-2016, 10:07 AM
No it's not working the test button...
06-13-2019, 06:27 PM
Never reply lol but for info I changed it and everything is ok
