Old 10-06-2015, 09:54 PM   #21
Bluepill's Avatar
Just to be clear: A factory-installed propane heater with an EXTERNAL air intake and exhaust does not add any water vapor inside unless it is defective. In that case your CO alarm should sound a warning. If you use a non-vented portable catalytic propane heater, it will add lots of water vapor inside.
My hardside thermostat will only operate in one mode at a time, so I cannot run both the heat and A/C at the same time. In order to dehumidify, I turn the heat up to 80 degrees, and run it until it cuts off. I then switch to A/C at 68 degrees. If it's very humid inside, I may have to do this twice. I monitor temp. and humidity with a small battery operated digital combo unit.
Link: http://www.amazon.com/AcuRite-00613A...or+thermometer
2008 Itasca Meridian 37H
Old 10-06-2015, 09:57 PM   #22
deartruc's Avatar
We use a Duraflame fake fireplace for the majority of the heat. The furnace is set to 65 just in case the Duraflame can't keep up.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 10-06-2015, 10:02 PM   #23
deartruc's Avatar
Our first 2 pups I ordered without furnaces. Figured 1500 watt heaters and heated mattresses would be fine. Sometimes an issue (poor campground wiring).
2017 GMC Yukon
2015 Roo 23 ikss
Old 10-20-2015, 08:10 PM   #24
Engineer of Crazy Train
ChooChooMan74's Avatar
Just spent 2 nights, one night in the 40s, the other in the 30s. No condensation. Used my PUPs, had reflectix window inserts, had all 3 tents with about 4 inches of unzipped window on top, and the bathroom fan on low.
Big difference between the 183 and 21BH... 1 electric heater kept the 21BH warm. Not so with the 183.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
bunk
