Old 03-19-2014, 02:43 PM   #1
Considering a 2012 Roo 21ssL
Found a used 2012 Roo 21ssL...looks like a possibility. Appears very lightly used. Anyone have any advice for this model and year? What to look for etc...Also, do all the 21ssLs have the off-road package...larger wheels and tires etc? thanks.
RACKMAN
2014 Roo 21ssL...towed by 2015 Ram Power Wagon
RACKMAN is offline   Reply With Quote
Old 03-19-2014, 03:02 PM   #2
cogito ergo moo
Cowracer's Avatar
21SSL is exactly the same 'box' as a 21ss, which is not a bad thing to be. So anything that applies to the 21ss will also apply to the SSL. I.E. check for water intrusion, blisters in the walls/fiberglass... Check axles and hitch for condition. Check smoothness of slide, look for any signs of critters, etc.
One thing is the paint on the deck is not very tough, so don't let surface rust scare you there. A quick wire brushing and repaint will make it all good.
Not all of them have the off-road package. Mine doesn't.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
2012, 21ssl, roo
