Old 05-22-2016, 08:08 PM   #51
Originally Posted by PenJoe View Post
I may be going against the grain on some of the suggestions, but I have been using this hitch for 10 years. Those of you who disagree should give this a try.
When hitching to the TV: TT wheels chocked front and rear. locate the ball of the TV under the cup, but slightly forward of the cup. The front curve of the ball should just touch the front of the TT cup. With the latch lever fully out, crank the TT jack down. The front of the TT cup will pull the TT slightly forward as is travels past the widest front part of the ball and then pulls back because the TT wheels are chocked. The TT hitch cup will be up against the front of the ball. The latch lever should seat into the locked position. You may have to tap it to make it seat. If it does not, make sure the latch locking around the rear of the ball has not bound up on the ball. It should not if the cup seated onto the ball. With the TT wheels still chocked, pull forward ever so slightly and the latch will seat. This only takes about a half inch movement forward. Remove the chocks and go.
When unhitching from the TV: TT wheel chocked front and rear. Unlatch the locking lever and crank the TT jack up. If the cup is seated with pressure on the front of the ball, cranking the jack will also start to lift the TV bumper. This is OK. Crank high enough so that when the ball falls out of the cup, it will at least expose half of the ball. Then put the TV in reverse and nudge back ever so slightly and the ball will drop out of the socket. Then crank the TT jack until it full clears the top of the ball and drive out from under the cup.
This hitch design on the TT is a very secure design, but they can be a putz hitching/unhitching. It is best to hold the latch lever out as far as possible while cranking to make as much room as possible for the ball. I would not recommend making any mechanical adjustments to make it work easier. Lubrication is fine. This hitch is what it is and you don't want any play when it is properly locked in.
A suggestion for those of you that have a TV backup camera. Paint the front portion of your TT hitch a bright contrasting color. When backing up to the hitch, it is much easier to see day or night even from a distance.
Thanks for the tip on painting it for visibility! Why wasn't that obvious too me? I went outside the minute I read your post...taped it up and painted.
2013 F150, EBoost,4x4,CC, MaxTow
2015 Surveyor 245BHS
tragusa3 is offline   Reply With Quote
