Old 02-05-2015, 06:51 PM   #21
Pretty brilliant mod for how simple it is...appreciate it.
sponge is offline   Reply With Quote
Old 02-05-2015, 07:30 PM   #22
when using the PVC mod. Is the the PVC attached to the bunk frame by bolts/screws? Trying to see if you have to unbolt/unscrew to release the bunk door.
JWHybrid2B is offline   Reply With Quote
Old 02-05-2015, 07:57 PM   #23
Jimandchris's Avatar
No, it just slides in over the seal opening from the side. The screws that hold the bunk end frame to the body keep the pvc from slipping off the edges. The only way to remove it is to slide it to the side straight out. If looking at the side, it cannot "turn" off of the edge. They are a bit of a pain to store when camping, but they do stay seem to stay in place when traveling. Others are doing the same thing with a slit garden hose, that way they are easier to store while camping. It does help to have a ladder or step stool to remove or install them.
ID:	69219   Click image for larger version
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 02-06-2015, 04:54 AM   #24
Originally Posted by syogerst View Post
I have had a hybrid for 11 years. 2 different campers. Never a leak. I don't understand how a vent fan can suck in the heavy bunk fabric. Could someone post a photo of this garden hose idea? Just can't picture it! Thanks
Closing bunks using exhaust fans.
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 02-06-2015, 05:39 AM   #25
Platokidd's Avatar
That was cool
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 02-06-2015, 08:55 AM   #26
Thanks for all the info on closing bunks with vent fans and also adding the PVC across the top of the bunk. Looks like I'll be trying a few new things in spring! Never had a leak, but better safe then sorry!
syogerst is offline   Reply With Quote
Old 02-06-2015, 11:14 AM   #27
You are all welcome! Glad to help out. It's nice to "give back" information to members here on the forum. I know the forum has sure provided me with help and answers the last two years.
2014 Roo 23SS
2013 GM Sierra CC
Equal-i-zer Hitch
Old 02-06-2015, 11:39 AM   #28
Question for the PVC'ers: What did you use to cut the slot in the PVC? How did you keep it a straight cut?
2011 Traverse LT, 3.6L, FWD
Old 02-06-2015, 11:56 AM   #29
I snapped a couple of chalk lines along the entire length of pipe, then used a sharp marker to make dots every 1/2 inch or so over the chalk to keep the cut straight. I then used a cut off jig saw blade to make the cuts. Used about half of the blade so it wouldn't try to cut thru the other side. I did have some clean up to do with a rasp but wasn't difficult.
Dado39 was considering using a table saw run slow enough not to melt the pipe, unsure if he has done so yet. That may work better. I did have some clean up to do with a rasp but wasn't difficult.
Jim
2014 Roo 23SS
2013 GM Sierra CC
Equal-i-zer Hitch
Old 02-06-2015, 01:49 PM   #30
Thanks.
