02-14-2015, 05:45 PM
#41
Roo rain guard
I was able to purchase a 10'-0" piece of clear flexible tubing for about $15 from Home Depot. I'm guessing that it may be a bit more expensive than the PVC. Anyway, I am attempting to post a couple of pics here of the mod.
Chuck, Heidi and our two dogs, Dixie & Gunner
2015 Roo 23IKSS pushing a 2012 F250 XLT
02-14-2015, 05:50 PM
#42
Roo Rain Guard
Hope the pics worked.
02-14-2015, 06:40 PM
#43
That looks good Chuck.
I went with 10 ft long 1 1/4" schedule 40 PVC as shown in the posted drawing. Cost was about the same at ~$15 per piece.
Not having a chalk line to hand, I ran a strip of 1" wide masking tape to form the cutting guide lines. My cuts did not come out terribly straight, but seems to fit OK.
I like the fit over the seals. Fitting the pipe was reasonably easy from one side of the trailer on a step stool.
I expect we will probably use these mainly for winter storage, along with our cover.
Thanks for the tips.
Stu
Stu
Calgary AB
2014 Roo 233S
2011 Ford Econoline Club Wagon
02-22-2015, 07:04 PM
#44
hamster
I used my table saw and it worked great. I used countersink screws at either end to fasten the wood to keep it from turning. Here are a few photos. I'm going to store them in the bumper since I use the fence post mod for the poop tube. Thanks to who ever came up with the idea and to Jimandchris for the great description and drawing.
[/IMG]
[/IMG]
[IMG] [/IMG]
02-22-2015, 07:53 PM
#45
That looks great! I never thought about storing them in the bumper...great idea.
03-01-2015, 06:56 PM
#46
I also use the PVC mod. I have a 2010 233S that had leaking issues. After replacing all the seals and pinch welt, I decided to use the PVC mod to prevent any water from entering the seal.
I used 1 inch angle iron, placing the two ends on the PVC, and ran a line down both sides. This gave me the perfect cutting measurement. Once cut, I glued ends on the pipe and cut slots on the bottom of both ends above the bunk latch. Purchasing material from the hardware store, I made two straps to hold each piece firmly on the gutter.
I also added an extra rain gutter to the side bunk as my trailer did not have one.
Hope this helps.
03-02-2015, 08:13 AM
#47
Very nice! Thanks for the great ideas.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
03-03-2015, 06:19 PM
#48
Originally Posted by Pappadeaux
I think that the PVC rain guard looks very clean & neat. I just wasn't feelin' the two cuts and the filing to get it to fit properly. I saw a post where someone suggested the use of garden hose slit and placed over the flanges. My OPINION was that the hose may too small in diameter. I had not noticed any leaks around the seal, but with all the conversation on FRF about the potential of a leak, i thought "an ounce of prevention...".
I'm the garden hose guy. I used 5/8 premium flexible vinyl garden hose. It fits perfect. It is self clamping. I have been using it for two years now. It has always stayed put while traveling. Very easy to store and install. Covering that top gasket is essential.
Les & Heidi Kramer
2021 Jayco Melbourne 24L
Olmsted Township, OH
03-06-2015, 08:41 PM
#49
Summer2Go
How to you put in on the door? Do you stand on a step ladder and slide it on? I would try the garden hose, but is it too flexible to slide on from the one side?
03-06-2015, 11:22 PM
#50
Used a piece of 1-1/4" (1"ID) clear flexible tubing cut to 7'-4" and slit down the middle.
Does that stay on while traveling? While the hose would be more convenient to store and install, the PVC seems less likely to blow off at highway speeds.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
03-07-2015, 07:01 AM
#51
I always carry a six foot step ladder. At first I carried it to check the tops of the slides for debris. You do need it to install the hose. The hose is a snug fit but works well. You can not slide it on.
Les & Heidi Kramer
03-07-2015, 07:03 AM
#52
No issues. It is a VERY snug fit and will not move in transit.
Les & Heidi Kramer
03-07-2015, 07:11 AM
#53
I always carry a small step ladder I purchased at Home Depot. I need it to remove the PVC pipes from the gutters and clean off slide outs before closing.
03-07-2015, 09:16 AM
#54
Summer2Go
So I ordered a183, and don't have it yet. I'm doing my research while I'm snowed in. Is it the front tent end that leaks? Or all; front, side, and rear tent ends?
03-07-2015, 11:30 AM
#55
Both my front and rear leaked.
Les & Heidi Kramer
03-07-2015, 08:49 PM
#56
All three beds on mine leaked. That's why I installed the extra gutter above the side bunk.
03-08-2015, 02:07 PM
#57
And none of mine have. So you never know.
2011 Traverse LT, 3.6L, FWD
03-10-2015, 05:13 AM
#58
I have not experienced any bunk leaks in my 23IKSS, but I'm not taking any chances. I installed a piece of 1-1/4" clear tubing over my rear bunk as well. See my previous post in this thread. Better safe than soggy!
03-10-2015, 08:08 AM
#59
I just did this mod using 3/4" vinyl tubing. Haven't had any rain yet but will let you know. I was able to find two 7 foot scraps that were unused for ,$5 at Ace hardware.
