Old 04-19-2016, 10:37 AM   #1
bott8961's Avatar
Dead converter
Good Morning,
I have a 2007 Shamrock 23RS with a dead converter. No 12 vdc, checked input at the board and with the nominal 120 vac in I have nothing out on the terminals supplying the 12 vdc to the distributing part of the panel. What I am having problems figuring out is if I have a 35, 45, or 55 amp main converter board. Bought the trailer used so no useful paperwork. The distrubuition panel itself has the part number listed as WF-8935/45/55. The only numbers on the main converter board are 9955-2 and AC04W064608584 both of which I cannot cross to anything useful. Any help would be greatly appreciated, thanks. David
David
2008 Toyota Tacoma Access Cab Pre Runner
2007 Shamrock 23RS
bott8961 is offline   Reply With Quote
Old 04-19-2016, 10:54 AM   #2
From what I can tell, looking up your model you should have a 55 amp converter.
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is online now   Reply With Quote
Old 04-19-2016, 11:08 AM   #3
fonzie's Avatar
try these guys....
WFCO 8955 Main Board Assembly
Fonzie
Old 04-19-2016, 11:30 AM   #4
AquaMan's Avatar
If you're going to replace, might as well get a Progressive and never have to worry about it again.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-19-2016, 07:10 PM   #5
bott8961's Avatar
Why progressive?
Amazon shows the progressive 40 to 50 dollars more for the dc supply depending on which current rating you go with. What does the progressive unit have that the original WFCO does not?
David
2007 Shamrock 23RS
converter
