Old 09-30-2015, 06:20 PM   #1
Detach TV - 2015 Shamrock 19
I have a 2015 Shamrock 19. Does the interior flat screen tv easily detach so it can be mounted outside? There is a two hole black mount installed outside from the dealer.
Shroeder is offline   Reply With Quote
Old 09-30-2015, 07:21 PM   #2
Yes. There should be a black power and antenna hook up also...probably below the tv bracket. l say probably because I don't have your model, but all Roos and Shamrocks have basically the same setups.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 09-30-2015, 07:54 PM   #3
deartruc's Avatar
Should. Not sure on your internal cabinet. But on mine I have to tie a string to the powercord end and pull it through so I can fish the cord back through the holes when I put it back in. Future mod...add an out let next to the tv.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 10-01-2015, 02:14 PM   #4
Pretty easy to move to the outside. You have to use the speakers in TV. Also make a note of where the cables go into the TV so when you move it back things will still work on the inside. It took me forever to get the connections back where they belonged!
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
shamrock
