Old 05-19-2012, 04:21 PM   #11
tabkld93's Avatar
I don't have photo capability right now.
The hitch is the equalizer 2.
tabkld93 is offline   Reply With Quote
Old 05-19-2012, 05:39 PM   #12
GASPEDDLER's Avatar
Originally Posted by tabkld93
We just to delivery of a 2013 surveyor 240 with the equalizer hitch. No problems hitching, but unhitching took a little time to figure out. My only question is can you back up with the hitch on? Dealer said not to, but I don't see that in the literature.
I have the E2 and yes it can be backed up. The trick to unhitching is to get the weight off the hitch/truck and onto the tongue jack. Those bars should slide right off once you get the tension off of them.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 05-19-2012, 09:58 PM   #13
bikendan's Avatar
only the cheaper WDH's that have separate friction anti-sway bars, need them disconnected to back up.
those WDH's with built-in sway control, like the Equalizer or Reese Dual-Cam, don't require anything disconnected to back up.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-20-2012, 03:35 PM   #14
cogito ergo moo
Cowracer's Avatar
A great habit to get into when disconnecting.
Always, always ALWAYS let your truck idle away from the trailer in question. I have seen quite a few times where someone hammered the gas, and forgot a safety chain or electric plug.
I creep away with the brakes half on till I'm about 4-5 feet away.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 05-20-2012, 04:31 PM   #15
bikendan's Avatar
another tip is to pull the ball forward in the coupling, whether hooking or unhooking.
this releases the coupler latch and makes it easy for the ball to clear the coupler.
in fact, when hooking up, i put the ball just ahead of the cup, so that when lowering the tongue onto the ball, it has to pull the coupler onto the ball.
and when unhooking, i make sure the tandem chock is on and i pull the truck as forward as possible, without moving the trailer.
Old 05-20-2012, 10:24 PM   #16
BeagleIL's Avatar
I too like to pull the truck forward a bit after setting the wheel checks. And when I do, the parking brake is rather helpful. If I don't set it, the truck's tranny unloads and rolls right back the where I started.
Mark, Jenny, Adam & Lucy
2013 Rockwood Roo 233S
2015.5 Silverado 2500HD CCSB with Duramax/Allison
BeagleIL is offline   Reply With Quote
