Old 02-23-2015, 03:19 PM   #1
2008 Flagstaff Shamrock
Do stick down tiles stay? Flooring
I need to replace cracked vinyl flooring. two questions
1.Will sticky back tiles stay for the long haul?
2. Will laminate flooring hold up to the moisture issues in trailers? We live in Minnesota.
bartoni is offline   Reply With Quote
Old 02-25-2015, 07:13 AM   #2
The sticky back tile will not hold up for the long haul - don't waste your money!
Laminate flooring will work if properly installed.
Good Luck!
rgthoma is offline   Reply With Quote
Old 02-25-2015, 07:22 AM   #3
Depends on the underlayment. We have it in our B&S master bath and it's been down for over 10 yrs and it still looks brand new.
Old 02-25-2015, 08:12 AM   #4
mud yapster's Avatar
You could always glue them down then they would stay put.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 02-25-2015, 11:53 AM   #5
stick down can work for long hall if installed properly. Make sure deck is clean if needed sand a little to rough it up a bit. then use a top quality floor adhesive with a lot of tack. then install tiles. I did this on my last toy hauler in the kitchen with a slide out over it and it was great for the next 5 years that I owned it. Even with a slide out rolling across it. They never slipped or moved.
j free is offline   Reply With Quote
Old 02-25-2015, 01:24 PM   #6
I do floor installs I would not use it that flooring is a quick fix but not for long the laminate is good if it stays dry if water gets on it and not cleaned up the flooring will separate no matter how you install it just my 2 cents
wildman is offline   Reply With Quote
Old 02-25-2015, 05:26 PM   #7
Thanks for the input, Does someone make a vinyl/plastic clip together product like laminate that resists moisture?
Old 02-25-2015, 05:45 PM   #8
Check out the Allure brands, i believe Home Depot carry,s it. I have done 2 trailers with the Allure and it is very durable and easy to install, Been down for 6 years and counting.
It more of a floating floor. Does not stick down to the existing floor,
Search Results forÂ*allure flooringÂ*at The Home Depot
Kevin & Judy is offline   Reply With Quote
Old 02-25-2015, 08:49 PM   #9
Thanks Kevin and Judy I'll check it out
Old 02-28-2015, 02:09 AM   #10
Has anyone installed a vinyl plank flooring in a northern climate like minnesota?
flooring
