08-19-2017, 08:48 AM
Do you like to "Rock and Roll"?
Just how much movement should I expect in my bunk ends? When someone on the sofa sleeper rolls over at night, we can feel it in the bunk ends.
We started with just chocks on the wheels and and the built in stabilizers. We could feel every movement. Then I purchased X Chocks. It helped a little but I can still feel movement.
I've been considering JT Strongarms or BAL Lock Arms but DW states, "It's a camper, it's supposed to move". She's recalling her childhood days in a pop-up.
So how much "movement" is expected and acceptable in a Hybrid?
Ron
Ron & Family
2017 Shamrock 23IKSS (Traded)
No longer active with Forest River Forum.
08-19-2017, 08:58 AM
In your ROO/Sham you are Sleeping at the End of the "Pivot Point" move to the center on the Table Bed! After 1 night on THAT BED you will not complain about Movement! Youroo!!
08-19-2017, 09:31 AM
We don't have a table bed. We opted for the table/chairs option.
Ron & Family
08-19-2017, 09:37 AM
Do you use X-chocks on both sides? I noticed a significant improvement after adding an additional X-chock. It won't prevent all movement, but it really helps. Make sure they are really tight (you can't over tighten them using the short handled wrench they come with).
You'll never be able to get rid of all movement. It's a lightweight trailer on wheels.
Eric & Abby
2016 Rockwood Roo 183
2014 Ford Explorer Sport
08-19-2017, 10:42 AM
I do use them on both sides and I tighten them until I start to see the rubber tread depress.
Ron & Family
08-19-2017, 11:01 AM
We've had a pop up and now a HTT and both have a lot of movement on one end when someone rolls over or moves on the other side. I did a lot of research on how to remove that movement from the HTT and was finally about to buy something when I realized that I was so used to it sleeping at night that I don't even notice it anymore. Accept it/ignore it, you will get used to it. If it really really bothers you then I would suggest looking at the Steadyfast products. I don't have any first hand experience but it's what I had settled on after doing a lot of research before I realized that I don't really need it. The other thing is that I'm all about maximizing my time and effort for setup/breakdown, doing as little as possible to get the most time camping and the least time setting up and breaking down. I realize setup of these items only costs a few minutes, but they all add up.
- 2022 Rockwood Roo 235s
- 2002 Avalanche 2500 8.1L 4x4
- 2017 Rockwood Roo 21DK (SOLD)
- 2001 Coleman Utah (SOLD)
08-19-2017, 11:04 AM
We have a 29' TT and even our 11 lb Dachshund can make the trailer noticeably move. I have X chocks on both sets of wheels and the corner scissor jacks. I bought a set of Screw jacks and put them under the frame near the axels to try to eliminate the bounce you get from the tires and suspension. They helped a lot but are a royal pain to put in and out as they are right where the two slide outs are. I'm in the process of installing a JT Strongarm setup and hope that does the trick.
Neil and Kimberli
2016 Silverado Z71 double cab
2016 Flagstaff 29KSWS Super Lite
08-19-2017, 11:50 AM
Ron, I agree with your wife.
With tandem wheel chocks and the stabilizers, it was good enough for us.
As was said, it's an ultralight trailer so it's not as rigid as other trailers.
08-19-2017, 01:02 PM
You can make any trailer very stable and firm but it takes work/money. The corner scissor jacks are very weak at stabilizing. The screw jacks are very good. It works. the strong arms are good too. Both together are fantastic.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
08-19-2017, 01:33 PM
Always Learning
Triangulation stabilizers, between the wheel chocks, step supports, and extra jacks. It all depends on how firm you want it.
You'll always feel some movement unless you lift the camper off of the springs but you can minimize/dampen it.
See if this helps:
http://learntorv.com/shake-shake-sha...stabilization/
For triangulation stabilizers, I like the SteadyFast system:
http://learntorv.com/product-review-...t-stabilizers/
08-19-2017, 01:46 PM
Just get some x chocks and jt strongarms, I wouldn't own a camper without them after using them as far as I am concerned they are a must have. They are a lot of work to install but really worth it, night and day difference, i also like the little step stabilzer i got off amazon, it is adjustable to the terrain.
2016 Shamrock 23WS
2018 F150 Ecoboost
08-19-2017, 03:30 PM
Wiggle
Originally Posted by Ron045
Get a foam topper for the table.
08-20-2017, 05:44 AM
a camper is not built on a concrete slab foundation like a house. Some movement is to be expected due to frame flexing, etc.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
08-20-2017, 07:33 AM
the way I see it short of jacking up the camper and put cement blocks under it. (walk in a mobile home that's on a lot and not set up you will feel movement. ) you have to get use to it or just stay in a motel
08-20-2017, 07:54 AM
X2 ^^^^^^
I guess this form of relaxation is not for everyone.
08-20-2017, 08:07 AM
DW's 401(k) Plan
Yeah, there's going to be some movement and that should be expected. However, I think some of it depends on what you get used to as well as the people using the unit. Our son is a big guy - 6'2" and 300#+. When he rolled over in our Roo, the people in the next site could feel it.
Along with X-chocks on both sides and a step support, we used Valterra stabilizers. One under the back bumper and one under the front of the frame behind the propane tanks. Took out the vast majority of movement. When we moved to a Flagstaff 27BESS, everything was transferred to the new unit.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
08-20-2017, 09:17 AM
08-22-2017, 06:50 AM
I use two X-chocks which are generally fine, but, I do notice that the stabilizers work their way loose and I snug them up daily. This could be part of the problem.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
08-22-2017, 07:02 AM
We use our organic stabilizers and X-chocks. As was stated it will move. One thing I did notice though is that the stabilizers are much more effective when they are not FULLY extended.
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
