Old 08-24-2015, 07:16 AM   #1
Dometic lost cool
Got up this morning and noticed my temp in refrig was 45 degrees,I have had it running on propane as we are on our way to Pa,It had been cooling great until now,My unit is new,I hear the refrig running when I go outside and listen but it is not cooling,HELP,Anyone with any ideas!
rmayo38895 is offline   Reply With Quote
Old 08-24-2015, 07:44 AM   #2
You may get more replies if you start your own thread as opposed to having this stuck in the middle of this one. But just to take a quick simple stab at it nothing happened to clog your vent tube on the roof did it?
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 08-24-2015, 08:32 AM   #3
KyDan's Avatar
Hi Ray- I have moved your thread to it's own starting point.
We need a bit more info-- Was your Dometic (note spelling, not domestic) refer running OK on LP gas before or were you on electric hook up??
Have you checked your LP gas supply by lighting a stove burner?
Does your fridge have a "check" light?? Is the check light on??
Try turning the fridge off and back on.
Go outside and listen carefully at the outside fridge vent.
You should hear a series of clicks as the fridge lights and then a subtle fluttering sound as the flame lights. The spark clicking should stop immediately when the fluttering starts.
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 08-24-2015, 05:17 PM   #4
If you've been driving down the road, check the location of the slider that sets the temperature. Unfortunately, DOWN is warmer. And if you hit a few bumps, it tends to slide DOWN.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
