Old 07-06-2011, 01:25 PM   #11
To the left of my draws is a large cabinet of the under sink storage and to the right is the fridge. I guess I could tie it to the cabinet next to it. I first have to deal with the frame as the 2 draws dont seem to close flush now..
Hybrid21SS is offline   Reply With Quote
Old 07-06-2011, 04:03 PM   #12
backin15's Avatar
I had the same problem with the drawers and the main support in back pulled loose causing the downward tilt. When I brought it in for repair the service guy showed me how to set the drawrs for travel - you have to shut them very firmly and a catch will engage which will prevent them from opening on the road.
We always travel with the table down.
backin15 is offline   Reply With Quote
Old 07-08-2011, 09:44 AM   #13
I finally looked more closely at it. The frame for the draws was attached to the floor with a single screw that came up. With the top draw removed and the bottom attached so I could level the draw, I replaced the screw and added a second. Not sure whats under it so I didnt go crazy with to many screws. Now the draws close flush but no matter how hard you push no catch engages so I guess I will try the bungie cord method..
Old 07-12-2011, 09:45 AM   #14
Bungie cord worked great !! Draws stayed in on the last trip
Old 07-27-2011, 09:58 AM   #15
NONI's Avatar
We had the same problem as you with the drawers, and like many have said we took the drawers out and added three screws to the bottom base-wood to add support. Problem fixed.
NONI is offline   Reply With Quote
expandable, hybrid, shamrock
