Old 05-23-2016, 08:18 AM   #21
This is what the slope looks like on my driveway.Click image for larger version
Name:	ImageUploadedByForest River Forums1464009524.165947.jpg
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 05-23-2016, 09:34 AM   #22
[QUOTE=Archicamper;1203759]This is what the slope looks like on my driveway.Attachment 108692
Do you put the front stabilizers down?
t0rnado is offline   Reply With Quote
Old 05-23-2016, 01:58 PM   #23
They are so far from the ground that I don't have enough lego block to reach them!
Old 05-23-2016, 03:08 PM   #24
Canadian Member
itat's Avatar
As you can see from my picture earlier in this thread, I made up some 15" high blocks by cutting some pressure treated 2x10s into 10" squares and stacking and screwing them together. If your tongue jack is extended out very far, the trailer will be a lot more stable if you can use the stabilizers.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 05-23-2016, 04:37 PM   #25
I'll take a look at making something like that for my stabilizers. My bigger concern is how the rear tire gets compressed and the front tire appears to be taking much less load.
Old 05-23-2016, 09:10 PM   #26
Canadian Member
itat's Avatar
You could put some boards or plastic levelling blocks under the front tires to transfer some weight to the front axle.
Old 05-23-2016, 09:13 PM   #27
Canadian Member
itat's Avatar
Correction: My stacked boards are 9" high (6 x 1.5" nominal)
Old 05-23-2016, 09:56 PM   #28
Iwannacamp's Avatar
If one fears.... You could anchor a plate...many types available in the concrete and attach a safety chain to it. Just in case. If I had an issue I would certainly do it.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 05-24-2016, 09:57 AM   #29
I like that idea but I need to figure out the logistics. As you can see from the picture, I am tight to my house and tight to the sidewalk. The ideal way to get the front wheel on the block would be to put the wood in front of the wheel and drive onto the blocks. Backing onto the blocks is more of a challenge!
I guess I need an outline of the blocks on the driveway like a body so I know where the blocks need to be before I back the camper up the driveway!
Old 05-24-2016, 11:41 AM   #30
Canadian Member
itat's Avatar
Can you fit a 2x6 or 2x8 between the front and rear tires and back the front tires up onto that? If not, you could just paint a dot on the side of the driveway where the board needs to sit (based on its current position), then back up over the board until the front tires sit on the board. Just have a spotter to make sure you don't back up too far and to make sure your front tires are sitting on the board.
If you're thinking about some kind of ramp for the front tires, that would be more difficult to keep the coupler behind the sidewalk.
