Old 05-26-2016, 06:02 PM   #31
Does this look ok?Click image for larger version
Name:	ImageUploadedByForest River Forums1464303745.971412.jpg
ID:	109148Click image for larger version
Name:	ImageUploadedByForest River Forums1464303769.321527.jpg
t0rnado is offline   Reply With Quote
Old 05-26-2016, 06:04 PM   #32
Name:	ImageUploadedByForest River Forums1464303821.976268.jpg
ID:	109150Click image for larger version
Name:	ImageUploadedByForest River Forums1464303842.594690.jpg
I chocked both sets of tires.
Old 05-26-2016, 09:15 PM   #33
Professional Curmudgeon
Looks great to me! You can get some really nice, large, solid rubber chocks at Harbor Freight for cheap that will last much longer and work much better than those hard plastic ones.
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
Old 05-26-2016, 09:58 PM   #34
CaptnJohn's Avatar
I cut a treated 4x4 and attached handles from ACE to make chocks.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 05-27-2016, 05:32 AM   #35
Canadian Member
itat's Avatar
I use 4 of those yellow plastic chocks. Works fine for me but I'm too cheap to invest in the big rubber ones.
For the tongue jack, I've done what you have but I would be more comfortable with a larger footprint for the blocking under it at least for the bottom portion. The previous owner of our Roo gave me a tree stump cut just right for that purpose and I kept it when we sold the Roo. You could just cut a 2x10 into 10" pieces and stack and screw them together to give you the height you need.
When I parked the Roo in our driveway I had to use a 2 step process to get the tongue high enough to level it. I first raised the tongue with the jack to near its limit and then temporarily rested the A frame on some axle stands that I placed on blocking. Then I placed the 14" high stump under the tongue jack with a 6x6 on top of the stump and lifted it to where it needed to be. It would work without the extra 6x6 but the 6x6 allowed me to avoid stretching the jack too high which made it more stable.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
