Old 03-06-2016, 09:52 PM   #1
urocav2001's Avatar
Dry camping
We will be dry camping this year for the first time, my question is would it be more efficient to buy another 12 v marine battery and bring it with us, buy a cheap generator, or a solar panel set, depending on how much we like it we may do it more times..
urocav2001 is offline   Reply With Quote
Old 03-06-2016, 10:14 PM   #2
You can get by on one battery for a weekend. If you're out all day an basically sleep in it you can go 3 nights easy on one battery.
If you plan to run your furnace overnight (Keeping it 70 in 20F-30F temps) you can run down two size 24DC batteries in 1-1/2 nights. A small generator may be best. It really depends on how much time you spend in your camper running 12v items. (lights, fans, water pump, TVs)
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 03-06-2016, 10:15 PM   #3
bikendan's Avatar
A cheap non-inverter generator, in a campground, will not be appreciated.
Unless you're talking about something like the Champion 2000w inverter generator.
A second battery will help but if you use the furnace every night, for more than 2 nights, they will get below 50%.
How will you deal with fresh and gray water?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-07-2016, 04:55 AM   #4
urocav2001's Avatar
Fresh water would have to be pumped from tank, grey would be dumped at dump station on the way out, I would not be using furnace, my trip will be near end of June..
Old 03-07-2016, 05:51 AM   #5
bikendan's Avatar
How many nights will you be dry camping and how many will be using the trailer's water and sinks?
Old 03-07-2016, 07:46 AM   #6
dcheatwood's Avatar
A small gen and external battery charger works for me. Run it a hour or so each day with charger connected to battery. Charges fast with external charger.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 03-07-2016, 07:52 AM   #7
Gold Miner At Heart
Papa-t's Avatar
X2 I have two Honda 2000's. But if you just need to charge a battery and run a few lights a 1000 would work.
Papa-t is offline   Reply With Quote
Old 03-07-2016, 08:20 AM   #8
KyDan's Avatar
With 2 standard 12v batteries we have dry camped for 5 nights no problem.
As you said- warm weather, no furnace, minimal lights- get LEDs!!
Make sure your fridge does NOT have anti condensation heater.
We pumped nearly a full tank of fresh water and even watched enough
TV every day to get local weather forecast using a little cigarette socket
inverter.
YMMV
Happy Trails!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 03-07-2016, 08:51 AM   #9
lswartz's Avatar
Find a local or state park near home & test it out. Then you can decide if a 2d battery etc. is needed based upon your needs. Caution, it is habit forming & you may be adding a 2d battery, generator, solar or all 3 at a later date.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 03-07-2016, 09:54 AM   #10
urocav2001's Avatar
Ok thanks, I will be dry camping 3 nights at a state park, unit already has led lights, state parks has restrooms and even showers but not hot ones so I should be ok with just the 2 batteries. Time will tell
camping, dry camping
