Old 07-14-2011, 02:00 PM   #1
DVD to TV hookup question
We purchase our Roo 21SS last fall, but only this week did we purchase a small TV for it. I was told that the "entertainment center" would play DVDs on a TV screen once we got one. Well I tried to hook it up this week and I cannot figure out how to connect the TV to the Entertainment Center where the DVD player is. Can someone help me with this? Please?
Scouter55 is offline   Reply With Quote
Old 07-14-2011, 02:19 PM   #2
frankm's Avatar
What is the brand/model of the entertainment system in your trailer?
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 07-14-2011, 02:29 PM   #3
Gosh, I don't recall off the top of my head. I'll have to check when I get home tonight. Whatever the Rockwood Roo came with in the 2010 model. The only way to plug anything into it is via either a USB port or a small plug.
Old 07-14-2011, 02:44 PM   #4
I believe you need to pull out the entertainment center and access the ports from behind. Knowing your model would help... Did you look at the manuals?
2005 Ford Excursion V10 4x4 4.30's
2011 Salem 26TBUD
brianb is offline   Reply With Quote
Old 07-14-2011, 02:45 PM   #5
frankm's Avatar
It is probably a Concertone. The USB port and the small plug (AUX) you see is what's upfront but there should be connections in the back of the unit as well. Knowing the unit's brand and model will make determining how to connect it to a TV a snap.
Frank & Rita M
Old 07-14-2011, 02:51 PM   #6
Our 21ss has a RCA video output next the the TV and satellite connections. It looks like a RG connection but its an RCA. We plug that into the TV video input and works fine through the on board DVD player..
2012 Jayco 33 RLDS
2004 Chevrolet Avalanche 2500
2007 TBSS AWD
Hybrid21SS is offline   Reply With Quote
Old 07-14-2011, 02:51 PM   #7
Why would they put the hook-up for the DVD to TV in a place that requires un-installing the Concertone from the wall? That defies logic! I was hoping for a simple plug in the from somewhere that I could just plug a cable into. Am I asking too much?
Old 07-14-2011, 03:02 PM   #8
Here is our 21SS...the single panel to the left of the double is a RCA video out jack..
Name:	IMG01724-20110714-1552 (Small).jpg
ID:	6815   Click image for larger version
Name:	IMG01725-20110714-1552 (Small).jpg
2012 Jayco 33 RLDS
2007 TBSS AWD
Old 07-14-2011, 03:12 PM   #9
Cause RV dealers make money off of installing TV's... It's not hard to remove just a few screws if it's even necessary. Consult your concerntone manual...
2011 Salem 26TBUD
Old 07-14-2011, 10:59 PM   #10
frankm's Avatar
I think because it makes for a cleaner and better looking installation by having all of the cables hidden or at least not in plain sight. All home entertainment systems (TV, game console, DVD player, VCR, sat/cable box, etc.) have their permanent connections out the back and one or two convenience (for occasional use) ports out the front. Yes you are right that it is difficult to access these "back" connections however once set up the system you should never have to touch (or see!!) the cables again.
Frank & Rita M
Old 07-15-2011, 07:32 AM   #11
Pictures are worth a thousand words. Thanks alot. I will try this tonight.
Old 07-15-2011, 07:48 PM   #12
rbq
The video from the DVD will go through the RCA jack to the video RCA connection on the TV. The sound should come through the speakers in the trailer. Make sure that you select the proper input on the TV menu. Works like a champ on our 233S.
rbq is offline   Reply With Quote
Old 07-19-2011, 06:58 AM   #13
Thanks to everyone who posted. The answer is that there is a single RCA plug just to the left of the coax cable hookups under the entertainment system. When I first looked at the RCA plug, I thought it was another coax... but upon closer inspection it really is an RCA recepticle. I plugged an RCA male end into this plug and the other end into my TV and I had video. As previously stated, the audio goes through the camper speakers... (which is why there is only one RCA cord required).
May I respectfully suggest to Forest River that they add this information to the users manual that comes with the camper.
Old 07-19-2011, 10:47 AM   #14
bikendan's Avatar
there's a lot of stuff we all would like added to the lousy FR owner's manual.
