Old 03-21-2012, 10:19 AM   #21
TURBS's Avatar
Originally Posted by Athens-M50 View Post
it is...i looked last night.
being it is for a FORD....I guess the wire colors would be correct....so I should be able to hard wire it into the 7way.
Yes!
Old 03-22-2012, 10:37 AM   #22
Athens-M50's Avatar
dropped it off at u Haul this morning......running out of time.
2002 17' Shamrock
2001 F150 Ext Cab
________________
2012 nights camped 6
Athens-M50 is offline   Reply With Quote
Old 03-23-2012, 07:51 AM   #23
Athens-M50's Avatar
***UPDATE****
Picked up from u Haul yesterday......They put a new 7way connector with a 4 way on the side of it($26.99).....fixed my rats nest under the truck where someone spliced in a 4 way into the 7 way wiring harness......mounted the brake controller.....ran wire for it......used a FORD connector to the brake controller( $6.99).....and tested EVERYTHING!!!!!!.....
$55.99 out the door !!!!!!!!!....wow
was expecting to pay at least $150 for that.
VERY happy!!!!!
hooked up the camper and adjusted brakes after I got home.
Doing the Happy dance!!!
Athens
2002 17' Shamrock
2001 F150 Ext Cab
________________
Old 03-23-2012, 09:08 AM   #24
Triguy's Avatar
That was a good price to get this completed.
And now you can
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-23-2012, 11:04 AM   #25
acadianbob's Avatar
Good job!! Since there is also a potential liability issue if you had an accident without brakes, this was a very good idea. Ford does make it easy. I changed my 2001 F150 from a 4 pin to to 4/7 pin. Easy plug and play. All the wiring was already there for a 7 pin.
Anyway, good job!!
P.S. You might want to check and see if the relay and fuse are in place in your fuse box for the "hot" wire that provides 12V to the trailer. For whatever reason, these are typically not installed at the factory. This allows you to charge the trailer battery while towing. If you have a 3-way fridg, it will also allow you to run the fridg with truck power while towing. Our pop-up had one of those and it was handy. Our Surveyor is only 2-way though so we have to use the propane while towing.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 03-23-2012, 06:55 PM   #26
kingranch's Avatar
Yes. The relay. Go to a scrap yard for a few bucks instead of parts store 20 plus
kingranch is offline   Reply With Quote
Old 03-23-2012, 06:57 PM   #27
TURBS's Avatar
20 plus ? your shopping at the wrong parts store !
mine was 8.99 at napa
brakes, expandable, hybrid, shamrock
