Old 06-07-2015, 05:11 PM   #1
Electric Awning
I am new to using an electric awning on the camper. The manual that
came with the camper says that when you hook up the camper to tow
vehicle, you should be able to go into the camper and hit the awning
extend switch, and the awning should not move. If it does you should
disable a breaker for the awning or remove a fuse so that the awning
will not come out while moving down the road. My awning is not disabled
when hooked up to my truck. Is this a real problem?
Has anybody had a problem with this issue?
dogevans is offline   Reply With Quote
Old 06-07-2015, 05:27 PM   #2
I don't disable mine while traveling. It seems like a bit of overkill erring on the side of caution. I do have an awning clamp though, but that is more to prevent billowing while driving.. not so much out of any concern it might extend by it's lonesome.
rana is offline   Reply With Quote
Old 06-15-2015, 11:58 AM   #3
I do not disable mine and have had no problems in over 3000 miles of driving with it
2008 F150 v8 5.4
2015Rockwood Roo 23SS
2015 Nights Camping: 39
2016 Reserved: 23
Davylee is offline   Reply With Quote
Old 06-15-2015, 12:16 PM   #4
Don't disable it electrically, but I do lock it down. Made several locks for other folks. If the motor should engage, it still won't open and if the motor should happen to burn out, I carry 2 spares jic.
The tabs require drilling an tapping the end of the roller, whereas the strap with the pin in it just requires sliding it in the open groove.
Name:	Alum tab, 3-8 x 1-2 ss bolt, washer & nyloc nut.JPG
ID:	80010   Click image for larger version
Name:	Awning lock top close up.JPG
ID:	80011   Click image for larger version
Name:	Awning lock turnbuckle.JPG
ID:	80012   Click image for larger version
Name:	Bottom hook unlatched.JPG
ID:	80013   Click image for larger version
Name:	Sunshade Groove 3.JPG
awning, electric
