You will also need something to create an air gap or foam insulation between the mattress and the bunk bottoms. The moisture from your body will penetrate the mattress and condense on the cold bunk bottoms and eventually cause mold. You can use 1/2" sheet of building foam insulation or a thin air mattress.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
