Old 07-19-2015, 05:07 PM   #1
Electric jack question
Hi! I took my 23ss camping for the first time without my husband. My battery wouldn't hold a charge no matter how long I had the generators running. Now I'm at home but my electric jack won't work to detach my truck. Now what do I do?
coloradofixgirl is offline   Reply With Quote
Old 07-19-2015, 05:17 PM   #2
Is the camper still connected to the tv? It should run off the electric of the truck unless the jack is broken.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is online now   Reply With Quote
Old 07-19-2015, 05:22 PM   #3
67cudafb's Avatar
Did you check battery disconnect to make sure it is on. You should be able to run them down with hand crank
1967 Barracuda fastback
2015 Wildcat MK 333
2010 Ram 2500 Mega-cab
67cudafb is offline   Reply With Quote
Old 07-19-2015, 05:25 PM   #4
bikendan's Avatar
yep, should be a way to manually crank up the jack.
ours came with a crank handle.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-20-2015, 06:13 AM   #5
Jimandchris's Avatar
Hope you were sucessful yesterday in disconnecting the tv.
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 07-20-2015, 06:43 AM   #6
( Use the Emergency Crank)! Sounds like your Vehicle and Gen are Not Connected to Charge your Batt! If you used your (Lights/Water pump/Refer/Slide/T Jack) you were running off Your Batt,so you didn't have the (Batt Disconnect OFF)! Youroo!! PS Cross Train before the Next Trip!
youroo is online now   Reply With Quote
Old 07-20-2015, 07:16 AM   #7
KyDan's Avatar
My Lippert tongue jack did not come with a manual crank but it does
have a rubber cap on top. Remove the cap and use your own electric drill or
socket and ratchet.
Agree with others- it sounds like the battery disconnect switch might
be off. Have to wonder how they got it hitched and to the campground??
Would love to hear "the rest of the story"!!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 07-20-2015, 07:16 AM   #8
Georgia Frog Rally 2018
aceinspp's Avatar
Check the hot wire from the jack there maybe an inline fuse under the camper near a junction box. I had one in my V-Lite. Had the same issue as you but found a bad wire connection after the fuse. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 07-20-2015, 07:58 AM   #9
Yep, would like to hear what the issue was. Not sure what year 23ss they have, our electric tongue jack is always powered and is ahead of the disconnect. Theirs should have worked if they were plugged into the tow vehicle - assuming they have power at the connector....
2014 Roo 23SS
2013 GM Sierra CC
Equal-i-zer Hitch
Old 07-20-2015, 08:15 AM   #10
cogito ergo moo
Cowracer's Avatar
I'm pretty sure if you are on Generator/shore power and do not turn on the battery disconnect, it will not charge the battery.
That could be why the battery won't charge.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
electric
