Old 06-09-2019, 04:31 PM   #1
pxt
Electrical Issue
One circuit keeps blowing a fuse( exhaust fan, dinnette light, front fantastic fan, and outlet). Replace the fuse a few times. What's next? shamrock 183. Thank you!
pxt is offline   Reply With Quote
Old 06-09-2019, 08:01 PM   #2
Does it blow the fuse with all these OFF?
If not, turn them on one at a time and you'll quickly find out which one is blowing the fuse. Then you can start looking at the wiring to that device.
2011 Traverse LT, 3.6L, FWD
Old 06-09-2019, 08:27 PM   #3
pxt
I will try that. Thanks
Old 06-18-2019, 07:59 PM   #4
pxt
Found the short!. The max air fan circuit board burnt out. Should I start by replacing the board or was it something else that burnt the board?
Old 06-18-2019, 08:07 PM   #5
Probably a bad board.
This forum is full of fridge, furnace and water heater board dying; first I've heard of a fan, but I'd buy a new one and move on.
electric, electrical
