Old 05-27-2015, 10:51 AM   #11
KyDan's Avatar
Most states the highway patrol will stop you if they see something "leaking"
from your rig. It's against the law to "dump" anything on the highway even potable water. I do also drain mine but it's done by the time I get out of
the camp ground.
Also added a 1/4 turn valve as others have mentioned. When I pull the
wheel chocks on that side, I open the valve...
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 05-27-2015, 11:36 AM   #12
We have only filled our tank a few times over the past year. When we were finished with our trip, we open the valve and let it drain. We do sanitize the tank and water lines at least once per year.
bfrtech is offline   Reply With Quote
Old 05-27-2015, 11:38 AM   #13
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
I don't recommend dumping it as you roll down the highway. You could get stopped. Just open it at your compsite. We keep about 5 gallons in it while travelling for the toilet. A couple times a year, since we're full timers, we add a couple cups of bleach to control mold and mildew.
Grampa Jim is offline   Reply With Quote
Old 05-27-2015, 11:57 AM   #14
Canadian Member
itat's Avatar
Do not drain the FW tank when you're travelling down the road or at the dump station. If we are camping within a couple hours of home I drain it before leaving the campsite. I try to time it so we don't have too much water in the tank the last morning so as not to waste too much. If you need the water for bathroom stops along the way, drain it when you get home or back to your storage lot.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 05-27-2015, 12:18 PM   #15
NYDP77's Avatar
I would drain it right at the camp spot. I've never heard of an issue with fresh water. Some states/campgrounds have regulations on gray tanks. Also, would hate to forget to dump it and it becomes unclean/smells.
DP
2013 Tracer 240 AIR
2014 Silverado 1500
NYDP77 is offline   Reply With Quote
Old 05-27-2015, 12:27 PM   #16
We pump all but a few gallons into the grey and black tanks before leaving to aid in dumping. Only takes a couple of minutes and a couple of full flushes will help stir things up. After dumping pull ahead and pump the remaining in the black tank and add chemicals. This does two things, gets the tank ready for the next trip and the drive will slosh the treated water around cleaning the tank.
Bob and Joy
2013 Sunseeker 3010DS
rhumbert is offline   Reply With Quote
Old 05-27-2015, 12:30 PM   #17
Pull the plug & let it rip - at the campsite, if the drainage is good. On the way home if the drainage is not good (don't want to leave a muddy mess for the next guy). We empty the fresh water at the end of each trip.
Joe & Sue - Camp Mutt Dazey
2008 Flagstaff Super Lite 26RKS
2008 Ford F-150
hotzfamily is offline   Reply With Quote
Old 05-27-2015, 12:30 PM   #18
Originally our drain had a plug that needed a wrench to remove. I changed it for a valve that was much easier to open. If I know the next place I am going to has water I just open it and let the water drain out as we travel.
RV- 2014 Thunderbolt XLR 386X12 Called "The Castle"
TV- 2013 Ram 3600 DRW Diesel Called "Hercules"
rick42wood is offline   Reply With Quote
Old 05-27-2015, 12:37 PM   #19
Mr. Dan's Avatar
Originally Posted by KyDan View Post
.... It's against the law to "dump" anything on the highway even potable water....
Is that true in all states/provinces/parishes?
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 05-27-2015, 02:55 PM   #20
We always run with 1/2 tank as we have too often arrived at a campground and they were doing repairs, city shut off water, maintenance flushes, etc. and no water was available or it was not potable. We have checked with the experts and they stated that 1/2 tank does not significantly affect the mpg.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
fresh water, tank, water, water tank
