Old 05-29-2015, 07:35 AM   #31
Mr. Dan's Avatar
Originally Posted by youroo View Post
Thats a Pretty Tall Order to ask if it (Is true in all States?) I would need a (Supreme Court Ruling) to answer this! Youroo!!
Exactly! That's what I'm getting at.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 05-29-2015, 07:52 AM   #32
Wolverine 1945's Avatar
I am not sure why carrying 15 to 20 gallons of fresh water, until you get home is a problem ? 100 to 160 lbs. ? We have never been on a long trip, so not sure what I would do, I do like filling up @ home, I know what I am getting, Soft - Filtered H20.
Back when we had a TT and owned land up north, I would drain water tank on our land, before we left, but not on the HWY !!!
I believe dumping water @ a camp site or on the HWY is very inconsiderate !!!
There must be a better way !!!
Wolverine 1945 is online now   Reply With Quote
Old 05-29-2015, 08:27 AM   #33
Inconsiderate Acts
Yes, for the most part I agree. I would also add that there are a lot more inconsiderate acts done at camp sites besides adding fresh water to the flora. Examples: not picking up your smoke butts and/or bottle tops, adding smelly bacon grease to the fire pit or that last pile of doggy poo before leaving. Oh! I think I just started a new thread for inconsiderates!
gfarmcafe is offline   Reply With Quote
Old 05-29-2015, 08:49 AM   #34
Because we owned or own land for about 16 - 18 years we have not spent much time in campgrounds, now that we sold our land and have a small MH we will be taking short trips, and I guess we will find out what goes on out there ???
I am think most campers are good people !!!
Old 05-29-2015, 09:36 AM   #35
Brother Les's Avatar
Could be considered Rude to dump water at a campsite that someone will come into after you. You would not want to come into a campsite that was wet and water was running and pooling in areas.
Brother Les
Old 06-29-2015, 07:52 PM   #36
While we are on the subject of dumping the fresh water tank, how often do you dump the water in the hot water heater? We often have 3-4 weeks between each camping adventure.
jwalt313 is offline   Reply With Quote
Old 06-29-2015, 08:03 PM   #37
Dump Hot Water Tank
We've gone all season never dumping the hot water tank. After arriving and hooking everything up, I'll open up a hot water faucet to let any air out, and then light the water heater. We've never had a problem. Hope this helps.
Old 06-29-2015, 08:09 PM   #38
Ford Idaho's Avatar
I drain it all, fresh tank, water heater, low points because I am never sure when it will go out again.
Old 06-30-2015, 07:12 AM   #39
I am with Idaho,,, I drain the hole system after each trip !!!
And get both Black & Gray tanks ready !!!
Old 06-30-2015, 07:27 AM   #40
Flybob's Avatar
I drain everything after every trip. Most times opening both faucets then low point drains will drain WH as well. If you want to see what happens if you don't drain. Put 10-15 oz of clean water in a Tupperware type container loosely cover it and leave it sit on the counter in your RV until the next trip. Before leaving open container.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
fresh water, tank, water, water tank
